1951 Ford F6 Dump Truck
Boon, Welcome to the forum. Chances are you have a 239 CID engine unless it has been bored or swapped. The F6 is much more than one ton rated. Check the data plate for rating. One of the guys on here may have a set of wheels, they're scarce.
What are your plans for the truck. Pictures?
Classic Haulers, Dennis Carpenter are good for parts.
Welcome to the group. I see you are in MO, what part of the state? If you are wanting tubeless 19.5" wheels I can help. If you want tubeless 22.5s I know that a couple of the guys have found partial sets, but don't know for sure that they are for sale. Whether anybody has a full set available right now I can't say, but suspect you might be able to piece a set together. A third option would be the safer side ring style 20" tube types, but I don't know of any available sets right now. Stu
Welcome to FTE! We seem to have several new guys from Missouri. That's awesome. I'm right in the center of the state.
We do love pictures.
Here is an excellent reference to have: 1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
It is well worth the $22.
Welcome to FTE. The f6 is a 2 ton truck. And as stated prior should be A 239 flathead.
19.5" wheels are a good option for replacent wheels and tire availablility.
Ive got some 22.5" wheels but still coordinating a possible sale on one of the sets.
Post some pictures of your truck. We love pictures.
All three options I listed are safe. It's just a matter of weighing the options. The 19.5 and 22.5s are tubeless and less hassle, the 20s are tube type like your current widow makers. The 19.5 tires are shorter than your stock 20s, while the 22.5s will be the same or bigger. There's been a lot written here describing the options. You might do a Google search on the subject using my user name. Stu
Are 19.5 wheels easy to find? They sound like the best option. Tires are almost touching the fenders now, so a little smaller would help. Gonna use the truck on our farms to haul firewood, gravel and whatever else I think needs to be moved. I'm not sure how the two speed rear end operates. Is it vacuum? Do you have to be rolling to change it, or can I just move the lever on the rear end? Where is the data plate located? Does the carb have a name on it? I'll try and post pics if I can figure it out. Do you do it in the garage?
If you have old yards in your area you might find any of the options. I've done yard tours through MO to find them with success. Otherwise you'd have shipping investment. I'll have to defer to the guys that have the two speed axle on that part of your question. The data plate is on the glove box door, and VIN also is located on the passenger side frame rail near the motor mount. The carb should be a Holley 97 iirc. To post pics it's easiest to use a Photobucket or similar account. Stu
<a href="http://s1146.photobucket.com/user/abestauffer/media/ford%20trucks/2speedaxleshift_zps1b5cda43.jpg.html" target="_blank"><img src="http://i1146.photobucket.com/albums/o536/abestauffer/ford%20trucks/2speedaxleshift_zps1b5cda43.jpg" border="0" alt=" photo 2speedaxleshift_zps1b5cda43.jpg"/></a>
on
Could we see some pictures? Here is how.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
