starting on bed
Cab is painted Viking blue bumper is wimbutonwhite along with cluster
Hope to paint bed this week have glazing on bed now used minimum amount of bondo on bed so trying to cover dents as best I can there's so many, and stretched metal on the sides tried to shrink worked some but still their will live with it
Had to cut the base from bottom on both sides could not find replacements
One new fender from Sacramento vintage then welded three tears in the other fender so $300 for bed then $800 to haul it from Tucson then $700 more in parts and hours of sanding wow do I whine about sanding
Yes Viking blue no two tone for me probably hav to sand
What is mar-k? Mercury? I have a sheet of aluminum diamond plate that I'm going to try to use on my bulkhead. I saw an F100 in Vancouver done that way and I think it looked pretty good. Good luck getting yours put back together. It's going to look good when you get it done, and all that sanding will have been worth it. I've got to get started on mine.
Phone 8005434959 or ck web that's who others buy from
Your 4wd is comming along nicely. Congrats Im hoping that one day my 63 goes together as well as yours. I look forward to the day I start all my sanding. Ill probably regret it once I start too. Im doing some quick dd body and fender on my 65 will start with filler and sanding on that one soon but nothing fancy that will come later.
