74 F100 Radius Arms and brackets
Couple questions. My left side radius arm bushing, the front piece is totally missing.
Can the bushing missing lead to wallowing out of the bracket hole that the arm rests in and is there a solution if this happens?
On my 77 F150 it looks like the radius arm bracket at the frame is of a little different design than on the 74 F100? Especially one of the rivets on the 74 being located right above where the arm is and gives very little clearance. I ask about this because it looks like a preferred method to change the bushings is to drop the radius arm bracket from the frame and you have to grind off/drill out rivets.
The part numbers are (RH) D8TZ-3B095-C, (LH) D8TZ-3B095-D. You'll notice the P/N start with "D8" so I would say that there was a design change over the years, but the later ones are listed as the replacement parts for the earlier models.
The '79 model took different brackets with the RH part number being listed as superseding the right hand D8 part number.
Thanks Mike,
The ones on my 77 F-150 - the left side had all bolts and the right side had like two bolts and two rivets.
On my 74, pretty sure I have one bolt and three rivets on both sides. But interestingly, the rivets are in different places and the brackets are slightly different designs.
I'll get pics.
I'll get pics.
See here http://www.ebay.com/itm/ford-pickup-radius-arm-brackets-oem-f100-f150-f250-lariat-4x4-73-79-4x4-4wd-/370715562009?pt=Vintage_Car_Truck_Parts_Accessories&hash=item56505e9019&vxp=mtr
Not sure if these are interchangeable
http://www.ebay.com/itm/74-79-Ford-Truck-F150-4x4-Bronco-78-79-Radius-Arm-Mounts-Dana-44-Frame-Brackets-/140947275061?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d11cbd35&vxp=mtr
