Oil dipstick issue
Never had a lokar for the oil but did have one for an automatic transmission. I can't say any thing good about them other than they are pretty. It was real hard to add fluid to the trany though the tiny hole in the fill tube. They did provide an adapter for it but it got lost right away so i had to come up with a funnel that's real small and will probably get miss placed too. Plus none of the fill markings on the dip stick were in the right areas.
Is this a FE? if not, you have my apologies....
FE/FT Oil Pan, Dipstick & Tube Data - FORDification.com
if a person were to plug the dipstick hole and somehow make a check plug in the pan itself(like a rear differential would be) would that be possible? i dont what level of the pan would be proper without having the pan out and filling it to make a mark. that would be a forever accurate but difficult to check oil. that was something i was wondering before. i know how hard it is to find new dipstick tubes.
i also thought of just threading the hole for pipe thread, insert a longer pipe nipple and attach a stick to a pipe cap. would have to trial and error the length of the stick but should work and be solid.
