Headers, F250 HD 351W - Ford Truck Enthusiasts Forums
Old 04-06-2013, 02:35 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
My son has a 96 F250 with the 351W engine. We have been looking at headers for this truck. All the ones we can find have the fittings for the O2 sensor and the EGR tube. What they don't have is fittings for the air injection located at the back of the engine on the exhaust manifolds. I was thinking we could fab up tubing so this will still work. Either dump it into the collector or the closest header tube. Has anyone put headers on this style of truck and how did you address the air injection? Thanks
Old 04-06-2013, 06:30 PM
trollin91x250 trollin91x250 is offline
trollin91x250 is starting off with a positive reputation.
I put hooker headers on my 91, they had no ports for any sensors or anything and the truck runs phenomenal, probably doesn't help but if you can't find anything else it's worth a shot
Old 04-07-2013, 02:45 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
If you don't have emissions test, you can do away with all of that stuff. My 89 doesn't have any of that stuff anymore and runs fine.
Anyway, I'm fairly sure that you can just let those tubes pump and not plug them in. I don't think they really matter. If there is a better solution somebody will know I'm sure.
Old 04-07-2013, 10:37 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
If you're doing away with the stock cat then the whole air injection system serves no purpose so you may as well remove it. The TAB and TAD solenoids must remain electrically connected with vacuum sources plugged, and the air pump itself can remain as an idler so you don't need a shorter belt.
Old 04-07-2013, 11:35 AM
V10man's Avatar
It does have to pass emmissions. My son has a Magnaflow cat he swaps on for that test. Rest of the time he runs a 3" Magnaflow muffler.
Old 04-07-2013, 12:26 PM
raystankewitz's Avatar
raystankewitz raystankewitz is offline
raystankewitz is gaining momentum as a positive member of FTE.
Quote:
Your smog is the same as Cali so you will have to either locate headers with the required ports or stick with the stock manifolds. Unfortunately, unless you want to swap exhaust systems for smog, there are no workarounds.
*edit* Found these: Flowtech Part #: 91668-1FLT Shorty Smog Headers. Sounds like this is the ticket.
Ray
Old 04-07-2013, 03:40 PM
V10man's Avatar
Those dont have the air injection port either.
Old 04-07-2013, 05:34 PM
GNR22's Avatar
http://www.summitracing.com/parts/jb...-250/year/1996
These claim to work with air injection. But they are ridiculously expensive. like more than $800
1986 E350 exhuast headers? mos68x 1968-2013 Full Size Vans 3 02-15-2016 12:19 AM
Headers! I need help albertjcast 1967 - 1972 F-100 & Larger F-Series Trucks 8 02-16-2015 06:38 PM
Changing exhaust manifolds for headers 1995 F700 Exhaustednottired Exhaust Systems 1 07-12-2012 01:46 PM
351w Headers??? AstroFab 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-16-2011 08:13 PM
351w Headers firebogger 1973 - 1979 F-100 & Larger F-Series Trucks 43 08-11-2011 03:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
