87-91 cowl in 80-86? - Ford Truck Enthusiasts Forums
Old 04-06-2013, 01:12 PM
kickingber's Avatar
kickingber kickingber is offline
kickingber is starting off with a positive reputation.
Truck is a 83,F250,without A/C,351w motor, My question is: Is a 87-91 cowl a direct replacement for the 80-86 cowl? (plug and play) Or is there some fitment issuse's that have to be addressed? like bolt holes or ect. If so what are they? The reason I ask is, I've ran into some heater problems. Truck was parked for a couple years under a large willow tree. Heater worked properly when parked, now you can hear the fan, but NO air?? after researching on here what it could be, I belive there is a good chance that leaves off the tree could have fell into the cowl and plugged something up. I plan on removeing the current cowl and cleaning everything. I have read that the 87-91 cowl is the fix due to the smaller holes in the cowl dosen't allow leaves and such to fall through. but I can't find out if it will bolt right in or if it would require a little "tweeking" before it will work? Any help would be appericated. Thanks in advance.
Old 04-06-2013, 01:15 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
It's a 100% bolt-in swap.
However, it is still a body panel, and you may still have to align it like you would the doors, fenders, or the hood. Be careful when you remove the donor one, or else you risk warping it. They're made of pretty thin sheet metal.
Old 04-06-2013, 02:25 PM
kickingber's Avatar
appericate the help
quote=Fordzilla80;13034956]It's a 100% bolt-in swap.
However, it is still a body panel, and you may still have to align it like you would the doors, fenders, or the hood. Be careful when you remove the donor one, or else you risk warping it. They're made of pretty thin sheet metal.[/quote]
Old 04-06-2013, 04:35 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
You will have to remove the lower windwhield trin and watch out with the hood while removing the cowl. I munged up my hood edge and cowl while pulling my cowl. Best use a 2nd person to help.
Also the 92 and up cowls are diffrent. I found out the hard way......
Old 04-06-2013, 05:01 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I have pulled them out and pushed them back in under the window chrome trim. I have had to get in there and work on the wiper linkage.
There may be better places to access your problem. You can clean a lot of leaves and junk out by taking the kick panels off and taking those access doors out. You can also take the heater blower fan out and do a lot of cleaning there also. These are all the places where the leaves like to settle.
Old 04-06-2013, 07:16 PM
oneowner83 oneowner83 is offline
oneowner83 is gaining momentum as a positive member of FTE.oneowner83 is gaining momentum as a positive member of FTE.
...or you can install window screening under your existing cowl. It works fine.
Bullnose headlight bezels and a couple of dashes. Bricknose grille lvin4jc Ford Truck Parts for Sale 0 01-14-2017 05:37 PM
83 rebuild 8086ford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 30 02-19-2016 12:18 AM
Front Bumper??? greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-22-2015 04:35 PM
80-86 bumper on 87-91 Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 6 08-17-2014 12:08 AM
Will a 80-86 tailgate fit a 87-91 bed? boggerted 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 05-28-2008 10:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
