just went weight my 2013 F250 XLT - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 04-05-2013, 02:07 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
2013 Ford F250 XLT, CC, 6.2, 3.73 rear , 4x2, 4/5/13
<O</OTruck with Me (250 lbs) and full fuel:<O</O
Steer axle 3,880
Drive axle 2,980
Total 6,860
Truck with ME in it, full fuel, trailer full water (water tank is between tongue and axle on trailer)
Steer axle 3,760 (max front 4,250)
Drive axle 4,060 (max rear 6,100)
Trailer axles 5,000
Gross 12,820 (GCRW 19,000)
I figured the total trailer weight is 5,960 and 960 of that is tongue weight (max is 1,250). My truck with me, full water and the trailer weights 7,820 lbs (10,000 GVWR ) Looks like 2,180 for wife and what ever else.<O</O
<O</O
Trailer 2006 KZ Frontier, 2303P-F
It's nice having a 3/4 ton truck after maxing out a 1/2 ton for years
Old 04-05-2013, 04:47 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
That actually doesn't seem too bad.
I weighed my truck at the last Ohio meet and it came in just over 8,000lbs with me (215) another guy (user Dim Sum, maybe 185lbs?) and a half a tank of gas. These trucks are pigs!
Old 04-05-2013, 04:48 PM
FordmanNJ's Avatar
FordmanNJ FordmanNJ is online now
FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.
I'm Jealous.... Makes me want my truck when I get one even more. I like the sound of extra capacity!
Old 04-06-2013, 07:37 AM
goingnorth goingnorth is offline
goingnorth is starting off with a positive reputation.
Thanks for posting the weights, it helps to see what a truck actually weighs compared to what the brochers say.
What does the door sticker say for cargo carrying capacity?
I am going back to a superduty, hopefully have new truck in 2 weeks, its bucked with no build date yet had vin for 2 weeks!
Old 04-06-2013, 07:56 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
Wow, your truck is light. I weighed mine and with a full tank and no one it it, it weighs 7368lbs on a 9600lb GVWR.
Old 04-06-2013, 08:01 AM
ATP Pilot's Avatar
Its a 2wd, which help with the weight, and the payload on the door jam is 3,253 and my GVWR is 10,000
Old 04-06-2013, 08:12 AM
Quote:
Nice, my payload is only 2259 if I remember correctly but it's enough for what I use the truck for. I haul a 660 imp gallon water tank on my flat deck as well as my JD compact utility tractor when needed and also have a 34 1/2 ft Flagstaff V-Lite travel trailer which weighs abt 8500.
Old 04-15-2013, 07:52 PM
FordmanNJ's Avatar
Update...
My boss and I took a ride today as he wanted to drive the truck. We drove past a local junkyard with a scale. With him in the truck (He is about the same weight as me) the truck weighed in at 7330 lbs. That is with 3/4 tank of gas. Once I transfer my truck box from the 150 to the 250, I should be just shy of 7500 pounds with me and a full tank which leaves 2100 pounds for the passagers, cargo and the trailer. Not bad in my book and enough capacity when it comes time to move up in trailer size.
Old 05-12-2013, 07:16 PM
scraprat's Avatar
scraprat scraprat is online now
scraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant future
I passed a Cat scale today, filled up the gas tank & me in the truck (210#), Leer Cap and maybe 350# of misc stuff.
Steer axle - 4340#
Drive axle - 3860#
Gross Weight - 8200#
I would estimate the truck @ about 7400# from the dealer.
Old 05-12-2013, 07:53 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
I'm going to run mine over the scales at our local elevator when I get it home, then again when I get all my tool boxes and hitch mounted, then again with the trailer loaded. The GVW is 13900 lbs so I know I won't be close on the truck but I will be at the max 5th wheel tow rating of 15600 lbs.
Denny
Old 05-12-2013, 08:00 PM
scraprat's Avatar
It will be interesting to see what the truck will weigh in empty then with operating weight.
Old 05-12-2013, 08:05 PM
ATP Pilot's Avatar
good info...keep the weights coming
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 08:17 PM
another 2011 - 2013 super duty fog light post ex90ranger Electrical Systems/Wiring 2 12-26-2012 07:33 PM
2010 f-150 Platinum chip/gear questions topnotch286 Computer Chips & Tuners 11 10-22-2010 11:16 AM
05-F150 question water 5 2004 - 2008 F150 6 02-28-2010 11:29 AM
Locked Up Clutch Fan How Mpg Decreases? RÖENTGEEP 1994.5 - 1997 7.3L Power Stroke Diesel 15 12-22-2008 07:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
