Gemmer steering box ID help
Old 04-10-2013, 10:49 PM
CB_Cyclone's Avatar
CB_Cyclone
CB_Cyclone is offline
I think its from a big truck, 5DC62 is cast in below the GEMMER. Any help would be appreciated. The mounting flange is bigger than our 57 F100.
Old 04-11-2013, 01:59 PM
FJones8668's Avatar
FJones8668
FJones8668 is offline
Any chance of a picture?
Old 04-11-2013, 07:07 PM
CB_Cyclone's Avatar
CB_Cyclone
Old 04-11-2013, 08:16 PM
spurredon's Avatar
spurredon
spurredon is offline
A larger size unit was used on the bigger trucks. However, the last pic of the end plate with the adjustment screw and lock nut looks a little different than I expected. I have the larger Gemmer unit in my F100. Took a few modifications but worth the extra mechanical advantage you gain. I can't give any help with the casting numbers and doubt if you will ever unlock their mystery!
Old 04-11-2013, 08:30 PM
CB_Cyclone's Avatar
CB_Cyclone
I would like to put this in a 57 F100, how did you do it? Trim the casting, open up frame area? Thanks
Old 04-11-2013, 08:50 PM
spurredon's Avatar
spurredon
I left the casting alone and just drilled the holes I needed. It fit inside the frame. It was a little tricky to make sure it was installed at the same angle to fit up next to the bottom of the dash. You will also have to make a change with the clutch return spring if you are using one.
Old 04-11-2013, 11:24 PM
FJones8668's Avatar
FJones8668
I finally found it in this book. that gearbox is out of a late model 1963 F350 part number C3TZ 3504-W
Old 04-20-2013, 11:32 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
5DC62 = C3TZ-3504-W .. Steering Gear Box.
1963/66 F350 model 84 Chassis & Cowl Open Drive-Away (no windshield, no cab).
Model 84 steering gear housing, steering shaft and worm are different than F100/350 model 81 conventional cab.
C3TZ-3524-N shaft & worm F100/350 81 conventional cab: 40 7/16" long / C3TZ-3524-R shaft & worm F350 model 84: 45 7/16" long.
Deez-67
225
03-30-2018 01:41 PM
co425
19
09-22-2014 02:09 PM
51PanelMan
24
07-28-2014 11:41 PM
Action4478
11-07-2009 12:28 PM
otpracer100
10-26-2007 06:52 PM
Quick Reply: Gemmer steering box ID help
