Air-Heater duct - Ford Truck Enthusiasts Forums
Air-Heater duct
Old 04-04-2013, 05:11 PM
billgrant billgrant is offline
billgrant is starting off with a positive reputation.
Air-Heater duct
I'm restoring my 78 F350 and can't find any place that sells new duct for this year vehicle. Where do these restoration people get there's? thanks
Old 04-04-2013, 06:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Welllll, I'll try it again .
Welcome to FTE Bill, there are a lot of good, knowledgeable people here.
Sooner or later you'll run into another Bill, Numberdummy, he's the go to guy for parts sources and info.
But to answer your question. Does your truck have just heat or does it have factory A/C? This will make a difference. Also if A/C equipped (as opposed to aftermarket a/c) the controls will be integral with the heater controls in the dash and there will be a huge evaporator housing in the engine compartment.
No one reproduces the a/c ducts and they're obsolete and haven't been available for years. No dealer or obsolete supplier has any either.
I see them from time to time on e-bay.
Old 04-04-2013, 06:25 PM
mikeo0o0o0's Avatar
If you do locate a set of ducts, one thing you might consider doing to make them last longer.
Mine were in good shape. I gently washed the duct with warm soap and water and set it out in the sun to dry thoroughly. After that I got a spray can of Plastidip and sprayed heavy coats all around the outside of the duct.
Hopefully this will reinforce the duct and help protect it.
Old 04-04-2013, 06:40 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
One of these days I'm going try and make an adapter to fit over the square holes for the center duct and vent housing to adapt just a round hose. Both my center ducts for my 75 and 77 were in good shape, but sooner or later they are going to deteriorate.
Old 04-05-2013, 10:57 PM
Thanks for the info. I think I'll go ahead and fabricate some light metal from the square registers to the round duct. I found some of that. won't be factory but at least it will work. thanks again guys. Oh and yes it has factory air. Hope I'll figure out exactly where the vacuum hoses go. Long way to go on the restro.
Old 04-05-2013, 11:49 PM
turbohunter's Avatar
turbohunter turbohunter is offline
turbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant future
Dennis Carpenter sells different diameters of tubing but it is round. You will need to fabricate or find the rectangular to round transitions to the vent.
Old 04-05-2013, 11:57 PM
Quote:
On my year (74 F100) the original Ford service manuals have a diagram of the vacuum runs.
I would highly recommend buying yourself a set for your year and model.
They are a great help with restoration.
They can usually be found on eBay.
Old 04-06-2013, 04:28 AM
privateer, eh's Avatar
privateer, eh privateer, eh is online now
Danger City Kitty
privateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud ofprivateer, eh has much to be proud of
Good tip Mike, thanks.
I sure hope you pulled out the seat there Bill. It'll save you a lot of wear, tear and cramps if you do and it may help finance the resto. LOL. I know my carcass is to sore to leave the seat in and I'm a small guy with big character .......
... flaws
Old 04-06-2013, 09:37 AM
460me's Avatar
460me 460me is offline
460me is starting off with a positive reputation.
In the pic above,mine was wasted.I used either 4 or 6" dia flex heater/A/C duct stuff and tie wrapped it.Worked for me.
Old 04-10-2013, 06:51 AM
Greyman Greyman is offline
Greyman is starting off with a positive reputation.
The XLT Lariat trucks came with solid plastic ducting behind the instrument cluster and over to the dash vent on the pass side, I have a set I got at a junkyard. Maybe you can find some around your area?
Old 04-10-2013, 09:31 AM
Blackfoot Big Block Blackfoot Big Block is offline
Blackfoot Big Block is starting off with a positive reputation.
Quote:
I believe you are partially correct...
Ford went from a fabric duct system on the left side to a hollow plastic duct system for that duct only. The center duct remained fabric and the right side was stapled cardboard.
This was on the later "dentside" trucks. I'm not sure what year they made this improvement, but it was not confined to the XLT Lariat trucks. All trucks with factory installed air conditioning got the improved left ductwork.
Old 04-10-2013, 08:06 PM
mikeo0o0o0's Avatar
Quote:
1979. Bronco's also got the improved duct.
Here's the later ducting.
Old 04-10-2013, 11:48 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
had one of those "improved" ducts in the classifieds here FOREVER and couldn't get anyone interested in it. I finally just gave it to the guy who bought my supercab with a bunch of other factory air parts since he was going to try & convert the thing to have AC.
defroster ducts DR Smith 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-03-2014 12:57 PM
240 6 cylinder AshleyFarms95 1967 - 1972 F-100 & Larger F-Series Trucks 4 10-25-2013 06:15 PM
Magic air fresh air systems firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 62 05-09-2010 07:52 PM
Intercooler Duct dpoelstra 6.0L Power Stroke Diesel 29 06-24-2004 06:20 PM
fresh air duct fatfenders 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 09-19-2002 11:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
