1979 f600 4x4 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1979 f600 4x4
Old 04-04-2013, 02:11 PM
wkmcaregivers wkmcaregivers is offline
wkmcaregivers is starting off with a positive reputation.
1979 f600 4x4
recently purchased 1979 f600 4x4 with rockwell axles and transfer case, must be one of the earlies ford factory 4x4 installations in medium duty class. not sure on trans, code m, think it is 5 spd clark. has 370 big block, p/s hydraulic assist cylinder on pass wheel and p/s cooler under hood. truck is double framed and has 6,000lb autocrane mounted on rear.
Toyota Power Steering Conversion skeleton 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-13-2010 05:32 PM
How many dents do you have ? DaytonaTunnel 1973 - 1979 F-100 & Larger F-Series Trucks 24 04-05-2010 08:43 AM
1979 F600 VIN & P/S Q's OldFords 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-14-2009 06:53 PM
1979 400 4x4 to 460 swap p/s and radiator hose ? Darwin Knutson Engine Swaps 3 05-23-2007 05:01 PM
1979 F100 - need A/C mryan1391 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-01-2006 12:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
