Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 04-04-2013, 12:53 PM
55fordv8's Avatar
55fordv8 55fordv8 is offline
55fordv8 is starting off with a positive reputation.
55 F100 power steering
Hi everyone,
We would like to put power steering or power assist in our 1955 F100. It is all original other than a 12V battery conversion.
It has a 239 V8 with three on the tree manual transmission.
Does anyone know the best way to go about adding power steering? I have read that using a Toyota PS kit may work but will it work with the column shift?
Any ideas or suggestions would be greatly appreciated.
Thanks
Old 04-04-2013, 01:06 PM
yamagrant's Avatar
yamagrant yamagrant is online now
yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.yamagrant has a spectacular reputation.
I'm going with the Toyota, but I read in Classic Custom Trucks, that CPP now offers a power steering box that may suit your fancy.
Old 04-04-2013, 03:22 PM
55fordv8's Avatar
Toyota seems to be a popular option. Do you know if it will work with the manual shift being on the column?
Old 04-04-2013, 03:34 PM
yamagrant's Avatar
That I don't remember, I'm a darksider,using an aftermarket column and floor shift. I'm sure someone will chime in with the answer.
Old 04-04-2013, 04:29 PM
AXracer's Avatar
AXracer AXracer is online now
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
I used an aftermarket column and floor shift with my Toyota conversion but the stock column can be modified and used. See here for options and modifying the stock column: Toyota Steering Box Swap For 1948-1960 Trucks .: Articles
I believe the CPP box is just an expensive remanufactured Toyota box. Used boxes can easily be found for 20.00 - 150.00.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 04-04-2013, 04:49 PM
yamagrant's Avatar
It sure does look the same but smaller. they do a side by side in the article. I don't know the price, but I can well imagine, it's not cheap. I paid just over $100.00 for mine (Toyota), and with the mid fifties mount,it fit like a glove.
Old 04-04-2013, 05:02 PM
AXracer's Avatar
Chuck Frank
When I checked, I think the CPP box was in the 500.00 + range.
__________________
Old 04-04-2013, 05:05 PM
yamagrant's Avatar
Just for the box, or does it come as a kit?
Old 04-05-2013, 01:58 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has a great reputation on FTE.bjmayberry2 has a great reputation on FTE.bjmayberry2 has a great reputation on FTE.bjmayberry2 has a great reputation on FTE.bjmayberry2 has a great reputation on FTE.bjmayberry2 has a great reputation on FTE.
bjmayberry2
Just looked it up
CPP5356PSK-OC 1953-56, with CPP 400 Series™ box, kit
inquire for price
I thought I read the kit was around $750.00
If someone calls please post the price.
__________________
BJ Mayberry
Old Guy with Trucks
54, 56 F100s & 56 Ford panel
All works in progress
Old 04-05-2013, 09:15 PM
AXracer's Avatar
Chuck Frank
Doing more research, I found claims that the CPP steering box is a recased Isuzu box. That makes sense that the box would closely resemble the Toyota box since Isuzu and Toyota were manufacturing partners.
__________________
Old 04-06-2013, 07:12 AM
55fordv8's Avatar
Thanks for the info. It is still unclear to me if the three on the tree shift will be a problem. I wonder how hard it is to convert to a floor shift?
Old 04-06-2013, 12:05 PM
AXracer's Avatar
Chuck Frank
The column shift is on a separate shaft and the linkage is above the end of the column where it would connect to the steering box. The shift portion of the column is a completely separate entity.
Changing to a floor shifter is also easy. Hurst and Mr. Gasket still make 3 speed floor shifter kits.
__________________
Old 04-07-2013, 02:48 PM
55fordv8's Avatar
Thanks for all the replies. The information has been really helpful.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Power Steering Question Choptopjimmy 1957 - 1960 F100 & Larger F-Series Trucks 3 08-26-2013 04:16 PM
Will the Power Steering for a 55 Sedan Fit on a 55 F100? Jag Red 54 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-24-2012 02:40 PM
69 Power steering adjustment help v8xploder 1966 - 1977 Early Broncos 4 10-03-2006 10:10 PM
volaire steering box flatgreen55f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-19-2005 01:48 PM
Power Steering jmacjr1125 1967 - 1972 F-100 & Larger F-Series Trucks 10 02-11-2002 02:46 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
