NOS Vs. Propane
Old 06-04-2003, 09:48 AM
Nate9982's Avatar
Nate9982
Nate9982 is offline
NOS Vs. Propane
Ok I am not too sure how to ask this question so here goes. I have a 99 F-350 psd 6spd 100k miles. I have a Diablo Delta Chip, full 4" exhaust, AFE intake, and Luk clutch. I want to make my truck a little faster but don't want to blow up my engine. So my question is nos or propane? Has anyone had any experience with nos? I know their are lots of people running propane and are very happy with it. I would like to run Bully Dogs NOS setup but can't get a clear answer from anyone about what kind of engine damage I would be introducing. I have heard that you can't run a diesel too lean but again just somthing I have heard.
If I would run nos it would not be full time just on occation when I would need that little extra get up and go. So what I have read and talked to people about there would be no damage done. Please correct me if I am wrong.
Any advise would be greatly apreciated.
Nate,
Old 06-04-2003, 06:55 PM
Quadzilla's Avatar
Quadzilla
Quadzilla is offline
NOS Vs. Propane
The guys that I know that have Nitrous, also have propane. I guess they use it at the same time as LP. With what propane did for my truck, I can't imagine wanting/needing more, but my system is still pretty new. Give me a little time for the novelty to wear off, and I might change my tune.
Old 06-22-2003, 10:42 AM
Psychostrkr's Avatar
Psychostrkr
Psychostrkr is offline
Talking NOS Vs. Propane
I use nos because I did not want a huge propane tank in my bed. Each system is just as good, I've used both, the only significant difference I noticed was egt's are alot lower{almost 300 deg.} with the the nos than propane. Your right about running it lean, but these systems, nos or propane, don't significantly change the mixture enough.
Old 06-22-2003, 10:56 AM
Quadzilla's Avatar
Quadzilla
NOS Vs. Propane
Psychostroker- I didn't want a propane tank in the bed of my truck either, so I mounted mine under the truck, FWIW.
Old 07-01-2003, 09:49 PM
Fordman4x4's Avatar
Fordman4x4
Fordman4x4 is offline
NOS Vs. Propane
How do the hp/torque numbers compair between NOS and Propane? What should you expect from each?
Old 07-02-2003, 01:16 AM
Psychostrkr
Fordman propane is going to be alot easier on your engine than any Nos setup. As for the numbers I use a 50 h.p shot pre turbo for dramatic lowering of egts. Talk to Quadzilla about the propane. He knows his stuff.
Old 07-04-2003, 04:17 PM
Fordman4x4's Avatar
Fordman4x4
NOS Vs. Propane
yea, i was thinking of doing a propane setup next since i've already done the usual intake, exhaust, pgmer, and gauges. but i don't know...how much of a pain it is to put in? where to put the tank? how long does a tank full last? do u use it all the time or just when u want that extra power? does anyone sell kits?
sorry for all the ?s but i want to learn more about it, and see if it's for my truck
thanks
Nelson
99 F350 SD 4x4 PSD Auto
84 Bronco 351W Auto
fishindave11
04-22-2007 10:34 AM
deleontow
05-24-2006 06:42 PM
bigdaddyjosh
3.8 & 4.2L V6
09-05-2004 01:39 PM
97psd
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-16-2001 12:57 PM
Quick Reply: NOS Vs. Propane
