NOS Vs. Propane - Ford Truck Enthusiasts Forums
NOS Vs. Propane
Old 06-04-2003, 10:48 AM
Nate9982 Nate9982 is offline
Nate9982 is starting off with a positive reputation.
NOS Vs. Propane
Ok I am not too sure how to ask this question so here goes. I have a 99 F-350 psd 6spd 100k miles. I have a Diablo Delta Chip, full 4" exhaust, AFE intake, and Luk clutch. I want to make my truck a little faster but don't want to blow up my engine. So my question is nos or propane? Has anyone had any experience with nos? I know their are lots of people running propane and are very happy with it. I would like to run Bully Dogs NOS setup but can't get a clear answer from anyone about what kind of engine damage I would be introducing. I have heard that you can't run a diesel too lean but again just somthing I have heard.
If I would run nos it would not be full time just on occation when I would need that little extra get up and go. So what I have read and talked to people about there would be no damage done. Please correct me if I am wrong.
Any advise would be greatly apreciated.
Nate,
Old 06-04-2003, 07:55 PM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
NOS Vs. Propane
The guys that I know that have Nitrous, also have propane. I guess they use it at the same time as LP. With what propane did for my truck, I can't imagine wanting/needing more, but my system is still pretty new. Give me a little time for the novelty to wear off, and I might change my tune.
Old 06-22-2003, 11:42 AM
Psychostrkr Psychostrkr is offline
Psychostrkr is starting off with a positive reputation.
Talking NOS Vs. Propane
I use nos because I did not want a huge propane tank in my bed. Each system is just as good, I've used both, the only significant difference I noticed was egt's are alot lower{almost 300 deg.} with the the nos than propane. Your right about running it lean, but these systems, nos or propane, don't significantly change the mixture enough.
Old 06-22-2003, 11:56 AM
Quadzilla's Avatar
NOS Vs. Propane
Psychostroker- I didn't want a propane tank in the bed of my truck either, so I mounted mine under the truck, FWIW.
Old 07-01-2003, 10:49 PM
Fordman4x4's Avatar
Fordman4x4 Fordman4x4 is offline
Fordman4x4 is starting off with a positive reputation.
NOS Vs. Propane
How do the hp/torque numbers compair between NOS and Propane? What should you expect from each?
Old 07-02-2003, 02:16 AM
Fordman propane is going to be alot easier on your engine than any Nos setup. As for the numbers I use a 50 h.p shot pre turbo for dramatic lowering of egts. Talk to Quadzilla about the propane. He knows his stuff.
Old 07-04-2003, 05:17 PM
Fordman4x4's Avatar
NOS Vs. Propane
yea, i was thinking of doing a propane setup next since i've already done the usual intake, exhaust, pgmer, and gauges. but i don't know...how much of a pain it is to put in? where to put the tank? how long does a tank full last? do u use it all the time or just when u want that extra power? does anyone sell kits?
sorry for all the ?s but i want to learn more about it, and see if it's for my truck
thanks
Nelson
99 F350 SD 4x4 PSD Auto
84 Bronco 351W Auto
79 351M; mods to run on propane? fishindave11 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 04-22-2007 11:34 AM
12:1 pistons on eBay 83Van Ford Inline Six, 200, 250, 4.9L / 300 0 07-10-2006 04:37 PM
Propane Injection & Turbo Question deleontow Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 05-24-2006 07:42 PM
nos and diablo chip combo bigdaddyjosh 3.8 & 4.2L V6 1 09-05-2004 02:39 PM
Propane 97psd Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 04-16-2001 01:57 PM
Tags
diesel, injection, nos, noss, ompair, propane, psychostroker
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
