shortening in WVO - Ford Truck Enthusiasts Forums
shortening in WVO
Old 04-03-2013, 10:29 PM
rocketman2440's Avatar
rocketman2440 rocketman2440 is offline
rocketman2440 is starting off with a positive reputation.
shortening in WVO
Hey guys, I was talking to a buddy today and might have a line on some oil. It would be from a donut place that adds chunks of shortening to their fryers. Could this cause a problem in my system, or would all the shortening solidify when cold and be able to be strained out? I would like to have a consistent line on some oil, but not looking to cause any damage to my system.. or my truck (wreck took care of that).
Oh and on a side note crossed 15,000 miles of running on veggie the other day!
Old 04-04-2013, 07:30 PM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
What kind of kit do you have?
Old 04-04-2013, 08:18 PM
No kit, homemade. Heated pickup, heated fuel filter, and electric fuel heater before the fuel hits the rails.
Old 04-05-2013, 08:25 AM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
I would think as long as you can keep everything hot, you should be okay. But it's going to solidify once it cools down.
You'll also have to be very careful about purging your lines before shutdown.
Old 04-05-2013, 11:49 AM
Do you think it would / could settle out during filtering at home? I have a cold upflow settling system. I just wonder if I could let the thick shortening work its way out before it even goes into the tank. While I am good about purging my lines I would rather not worry about it at all.
Oh and I know nothing about shortening, other than it makes donuts delicious. Which is why I ask.
Old 04-05-2013, 12:59 PM
flainn's Avatar
Quote:
I don't really know. Maybe see if you can get a small sample and let it sit for a week or so to get an idea of how it behaves.
I would think you'll have much better results running this during the warm months. If you want to use it in winter you might need to consider HOH fuel lines.
Old 04-05-2013, 01:07 PM
I think you are right about the summer months. Being in Georgia that is a good period of time too! Well guess I need to get a sample. Thanks.
Old 04-06-2013, 01:28 AM
if you are using cold upflow, i doubt the shortening would even make it to your second barrel. But since you have lots of heated components, it wouldn't be a problem in theory. As the other poster mentioned, make sure you do a comprehensive purge. It'd be a shame to clog your veg fuel lines with shortening. If you aren't already running HIH or HOH or at least TOT or TOH, you should probably install that. all my veg rides have TOT, and it heats the veg in addition to the FPHE's i have.
Old 08-09-2013, 09:29 AM
Clay H's Avatar
Clay H Clay H is offline
Clay H has a very good reputation on FTE.Clay H has a very good reputation on FTE.Clay H has a very good reputation on FTE.
PHO is a PITA to filter and in a cold upflow system, your going to hate it. Consider a heat, settle method or heat and centrifuge. Way better than cold upflow.
Old 08-12-2013, 09:33 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Wonder what happened??
I have burned 'shortening' in my truck. This stuff is SOLID at 80*, but my system has a LOT of heat. After settling and filtering the stuff while it was hot, I put it in my truck. The next AM it was 20* and there was a drip on the top of my tank that was so hard I couldn't push my fingernail in it... Truck ran like it always does!
The biggest problem I see with burning donut oil is looking like the Pied Piper with a line of cops following you around.
68 LWB to SWB conversion. Driveshaft? Uni Moe 1967 - 1972 F-100 & Larger F-Series Trucks 19 01-06-2014 01:54 PM
How do I shorten a 1957 F600 frame ireding Large Truck 16 08-25-2013 09:19 PM
Shortened long bed? Stephen67 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 11-24-2009 05:34 PM
Shortening your Long bed via frame cut mfire138 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-09-2009 08:27 PM
Steering column shortening krzcwby 1967 - 1972 F-100 & Larger F-Series Trucks 1 08-28-2006 12:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
