Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Old 04-03-2013, 07:40 PM
02TB250's Avatar
02TB250 02TB250 is offline
02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.
www.facebook.com/Smitty1025
My 02 Build thread
I figured I should finally get around to making a build thread.
First day she was home:
Click the image to open in full size.
Little bit about my truck
Year: 2002
Drivetrain: 5.4/4r100/4.10
Body: Supercab Shortbed
Most Current Picture
Things I've done(will slowly become organized and catagorized):
Recon Smoked Cab/Mirror lights
03+ Mirror swap
Bilstein 5100 Shocks and steering stabilizer
Readylift 4" rear block (F350 conversion)
Backrack
20% 3M Tint
Energy Suspension Sway bar bushings
Door seal mod(iffy on whether it's worth it)
SPD SS Y-pipe
Mac Flowpath muffler
Moog ball joints
Kenwood Head unit, Speakers, 4 way amp
LED reverse/cargo Lights
Weather Tech Floor mats and Visors
285/75R16 BFG AT TKO LRE
R1concept Rotors and Hawk LTS Pads
Moog upper and center link
Things I need to do:
Lower draglink
Fumoto Drain Valve
Coolant flush
Trans flush
Front/rear diff change
Things i want to do:
05 Headlight conversion (stock grill and bumper)
08 Tailgate
LED taillights
LED interior and exterior upgrades
Derale 13011 trans thermostat
6.0l Trans cooler
Transgo 4r100 HD shift kit
Sound deaden interior
OBA with train horns
UnderCover swing cases
LED Light bar (thinking 30" factory headlights are just terrible)
Comments, questions, Let me know.
Thanks for all the help on here. It's a lifesaver.
__________________
Justin
~ 02 F250 Build Thread~
Old 04-03-2013, 08:06 PM
acf6's Avatar
acf6 acf6 is online now
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
miles.degrandi acf6
Man the solid blue looks so much better than the two tone
__________________
Miles
2003 F350 KR 4x4 - 6.0L
-ARPs, egr delete, coolant filter, blue spring, 5" MBRP, S&B, SRL+, SGII/EV2s, Flight Fab trac bars, 4" lift/35s, empty wallet, etc
coming soon: BPD water pump, Dieselsite HPOP, running for more than a week
Old 04-03-2013, 08:29 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is online now
Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.Redneckfordf2502002 has a spectacular reputation.
looking good. Have a 02 V10 ourselves so subscribing for any ideas. I hope to do a 6.0L trans cooler upgrade too. when you do the 08 tailgate are you going to do one with the tailgate step or just a regular one.
Trav
__________________
More Fords then GMs but still not sure if we have enough! Wishing the Harley list would be as long as the ford list
Build thread For White Lightnin': 88 F150 4x4 308 C6 W/ shift kit 31s fender flares bed caps & rails bug deflector black mirrors with more to come
White Horse: 10 F150 4x4 5.4L custom pinstripe & spray in liner more to come
Got a ton of more trucks!
Old 04-03-2013, 10:32 PM
02TB250's Avatar
Quote:
Trav
I would probably like the step but i do not want the handle. I believe from reading on here that i can buy a tailgate with a step and remove the handle, which will probably be what I'll do because i use my tailgate as a seat and to slide things in and out.
__________________
Justin
Old 04-04-2013, 06:51 AM
zombie4x4 zombie4x4 is offline
zombie4x4 is starting off with a positive reputation.
Quote:
yea i have read that you can remove the handle which i am looking to do to mine as it is only in the way and just gets scratched up. but the step is a great feature! great looking truck! i love the look of the SC SB
Old 04-04-2013, 10:36 PM
02TB250's Avatar
Sadly it took me almost 6 months to get one of these. But here's a clip of the exhaust. I was not driving so I don't know what the RPM or throttle was at any point
Enjoy
__________________
Justin
Old 04-05-2013, 09:38 AM
wizkid00104's Avatar
wizkid00104 wizkid00104 is offline
wizkid00104 has a good reputation on FTE.wizkid00104 has a good reputation on FTE.
Do you get a lot of interior resonance with the MAC?
Old 04-05-2013, 09:53 AM
02TB250's Avatar
Quote:
Is a drone at 40-45, which I believe is 1200~ rpm. But it's no where near as bad as flowmasters I've had on previous vehicles.
__________________
Justin
Old 04-19-2013, 11:41 PM
02TB250's Avatar
Finally had time off of work to do the very important upgrade to my brakes
I got my rotors from R1Concepts, Hawk LTS, New upgraded front pins, new rear pins and the pad hardware for the tune of 650-700$
Initial reaction: It is so nice to be able to touch the brake pedal and not have the steering wheel and pedal pulse like a roller coaster. The brake force on the truck has easily increased.
Side question.... My pads were cracked and the rotors had huge hot spots, some as big as dimes. Is there a way that i can avoid this happening in the future???
__________________
Justin
Old 04-20-2013, 01:25 AM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
When I saw those tail gates 1st come out with the step on them, I said "Man, thats so stupid and useless. "
Now, I wish I woulda got one, because it is a really nice thing to have haha!
__________________
I am putting a dt360 engine in a 2008 f250:
http://www.ford-trucks.com/forums/13...0-project.html
Old 04-20-2013, 03:52 AM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is offline
Bently_Coop has much to be proud ofBently_Coop has much to be proud ofBently_Coop has much to be proud ofBently_Coop has much to be proud ofBently_Coop has much to be proud ofBently_Coop has much to be proud ofBently_Coop has much to be proud ofBently_Coop has much to be proud ofBently_Coop has much to be proud of
Hot spots in the rotors may be from towing. Best way to avoid this is cryo treated slotted rotors or get yours turned after you tow.
Truck looks good. Like the solid color and the tint.
Did the sway bar bushings remove a lot of noise under the cab?
Old 04-20-2013, 06:52 AM
02TB250's Avatar
Yeah, since I did the rear block and 285s the tailgate is another 2-2.5 inches in the air it would have been nice especially when loading up the bed with scrap last night.
The sway bar bushings did not get rid of all my clunking under the cab. They got rid of a lot of it, and did give me a HUGE increase in turning stability, but I think I have a bad body mount under the driver side that I have to diagnose a little more.
__________________
Justin
Old 04-20-2013, 08:54 AM
acf6's Avatar
miles.degrandi acf6
I had a clunking also and it turned out to be bad upper front shock bushings
__________________
Miles
Old 04-22-2013, 07:11 PM
02TB250's Avatar
Quote:
The only reason that i don't believe that it's the shocks and I'm leaning toward the body mount is because the Shocks, Swaybar bushings, Ball joints, and Spring isolator pads are new... So i think the only thing left is Spring bushings and body mounts. and the spring bushings "look" okay.
__________________
Justin
Old 04-26-2013, 08:05 PM
02TB250's Avatar
Did my first real work in the truck today. I don't know how much it was but it was just about to rest on the over load springs.
Just hitting the overloads
Anyone know about how many yards this would be I had to load it myself
__________________
Justin
Similar Threads
F250 Paint and interior reconditioning PETE'S_6.0PSD Appearance & Dress-Up 2 11-20-2014 03:08 PM
Help removing wires 02TB250 Super Duty & Heavy Duty 2 11-12-2014 08:12 AM
steering box question. 02TB250 Super Duty & Heavy Duty 3 08-10-2013 09:44 PM
Torque values run6.0run 6.0L Power Stroke Diesel 11 02-21-2013 10:16 AM
New Truck Buck 92 1987 - 1996 F150 & Larger F-Series Trucks 28 03-10-2011 01:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
