Does anyone know a lot about oba compressors and tanks and lines and such? I picked up a 5 gal tank and 2 480c compressors and need to know what other fittings lines and sizes I need to go about getting?
How much do those boxes hold? Can you put a gallon of oil in one?
I'm not sure about a gallon, it's pretty spacious, so depending on how it's shaped maybe.... But you could put 2 or 3 quarts in there. I have 20ft of chain, a 30ft ****** strap 4 shackles and a pintle hook in one. So there is a lot of space.
Updates look good. I like the swing case in there but are they removable? For when hauling dirt, lumber or dump runs.
Yup. They remove from the mounting bracket giving you your entire bed back. Depending on the bed liner you have or cover or whatever you'll have to cut it to fit the brackets and allow the case to swing closed. I'll post pictures today.
Justin, I'm not too familiar with how the compressors work but why did you pick up two of them instead of one?
It was the kit that I saw and bought, it came with two compressors and the 5 gallon tank. the dual compressors will air up much faster. According to the specs, it will go 0-200psi in under 4 minutes. so it's just more convenient, for when i need air, i have it.
