My 02 Build thread
#201
Hrm... I really like that. That would make the light bar mounting so much nicer.
I think if I do ladder bars I'm planning on doing a 5" block with ladder bars and a 2" leveling spring in the front and air bags to stop the sag when I haul mulch or scrap. So the block one from PMF suspension is so appealing, I'd get more height and no wrap.
#204
Updated List
Most recent picture:
Exterior:
03+ Mirror swap
20% 3M Tint
08 tailgate with step and camera
Backrack
Body Color grille
16x9 -12 offset teflon ATX Artillery rims
Suspension:
Bilstein 5100 Shocks and steering stabilizer:
Readylift 4" rear block (F350 conversion)
Energy Suspension Sway bar bushings
Moog ball joints
Complete Moog drag link
Lighting
Recon LED taillights
05 Harley headlights with h1 4300k projectors
Recon Smoked Cab/Mirror lights
LED reverse/cargo Lights
LED fog lights with gloss black reflectors
Exhaust:
SPD SS Y-pipe
Mac Flowpath muffler
Everything Else:
Door seal mod
Pioneer flip upe Head unit, Speakers, 4 way amp
Weather Tech Floor mats and Visors
285/75R16 BFG AT TKO LRE
R1concept Rotors and Hawk LTS Pads
Fumoto f106 oil drain valve
Undercover drivers side swing case
Undercover Passenger side swing case
Viper 5101 remote start
Things i want to do:
Visual:
Body color 05-07 Grille, Still unsure if i want a Billet style or standard
30" LEDwarehouse single row LED bar behind grille
2-3" cowled hood
08 Mirrors with PTM caps
08 Rear bumper
Recon smoked LED 3rd brake light
Fuctional:
2" procomp front lift springs
PMF ladder bars with 5" rear block
OBA with airbags to reduce sag when loaded
Interior:
Modify 05 trashbag holder to hold brake controller
move amplifiers under front seats
molle straps under 2/3 rear seat for mounting gear
1 or 2 10" subs behind rear seat using RUNVS's experience and guide
08 center jumpseat
Unfortunately most of my want list is going to take a while if it happens. Life is starting to get in the way of modifying my truck. So I'll be doing this mostly when funds allow.
Exterior:
03+ Mirror swap
20% 3M Tint
Backrack
Body Color grille
Suspension:
Moog ball joints
Lighting
Exhaust:
SPD SS Y-pipe
Everything Else:
Door seal mod
Visual:
2-3" cowled hood
08 Rear bumper
Fuctional:
Interior:
08 center jumpseat
#205
#207
The truck looks great Justin, really liking the mods so far. Really like the smoked lights and tint too. I think I'm going to get the same 20% on mine too. If I remember right you had it professionally installed, how much did it cost you? Did you just do the front windows or all of them? I was thinking about maybe redoing all my tint with new 20%, but not sure if it would be worth it or not. Factory tint on the rear windows is about 20% right?
#208
The tint cost me 75$ a window. So 150$ for the front 2. Has held up very well for the last year and a half or so.
#209
I got a little work done yesterday. I used fatmat, got a 25 sqft kit with install tools for a decent price of Amazon.
I finally put something behind the back seat so it's not just sheet metal. I also did the rear doors. It's not perfect but pretty good for a first attempt. I have enough to do the front doors as well and will probably do that my next day off.
First impressions are that it does what it's supposed to do. Stops vibrations and cuts out a little road noise. I'm still planning on replacing the cotton matting with a proper sound deadener but will do that over the summer.
I would like to the floor as well, but I'm slightly worried about the seat bolts being rusted/stripped. When I went to install my sound system one of the rear seat bolts just felt like it was spinning.
#210
Justin how much did thta run you? Now that my interior is literally all apart except for the carpet I have been thinking about doing some sound deadening while its out.
Are you referring to the matting on the doors?
I wouldn't worry about the seat bolts, I was worried the first time when i had to install my 08 console but once you get them out the first time if you spray them with some WD40 and the holes then reinstall them they usually come out every time without any effort. I have taken my seats out once a year for the past three years and never had an issue after oiling them, first time took some force now it's easy though.
