196? Econoline Pickup VIN Decoder - Ford Truck Enthusiasts Forums
Old 04-03-2013, 10:59 AM
black*shirts black*shirts is offline
black*shirts is starting off with a positive reputation.
Can anyone decipher the following VIN?
E10JH711176
Thanks in advance...
Old 04-04-2013, 05:12 PM
EmilBarnabas EmilBarnabas is offline
EmilBarnabas is starting off with a positive reputation.
Old 05-19-2013, 09:44 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
I deciphered it using the Ford Master Parts books...I got the same info as the above link...one possible variable...the sequential build date is the same as is used on the F series trucks which also comes out as a July 1965 Build date...its possible that the E series had a different setup for the build date info.
- cs65
BTW...Im not sure if black shirts had also added the rest of the warranty plate data or not, but the info for the whole tag came up...
Old 05-22-2013, 05:51 PM
We found through years of folks across the country crawling under Econolines that the serial numbers did not line up exactly as the Ford Parts Book. The problem was around 1964 and 1965. The website is what eh Econo experts all agree on.
Rear Bumper -- Step Pads VaSheriff Excursion - King of SUVs 2 07-13-2010 06:19 PM
174XX? What is it? Orezona 1999 - 2003 7.3L Power Stroke Diesel 10 08-29-2009 09:39 PM
Lemon Law Title - Oasis VaSheriff Excursion - King of SUVs 33 04-26-2009 09:49 AM
Frame Specs Fabman54 1947 and Older Ford Trucks 19 11-25-2008 06:15 PM
Nomination SuperSnake North Carolina Chapter 14 09-21-2006 10:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
