Recently Purchased 1987
First, I`m new and I'd like to introduce myself, Im from KCMO, Im 18 and Ive got a 1987 F150 Lariat that Ive got a ton of questions about. Its got a 302 V8, an automatic trans that I assume is a C6, long bed red and white two tone 2WD. It has 160k miles, no power bells and whistles and is completely stock aside from the tires. It has little rust aside from the hood and rear passenger wheel well. So my questions are: When can I expect transmision issues? If I get proper tires is it offroad capable? Should I buy a new hood or paint the current one? What usual maintainance do you recommend? I appreciate any and all responses thanks!
If it really is a C6 tranny (do a search on this forum, I'm sure there is a thread about figuring out what tranny you have) don't expect too many problems. But if you aren't doing proper maintenance like fluid flushes and the like, you might want to think about doing it. Tranny issues is a Dodge problem, not Ford.
What kind of offroad driving are you looking to do? Of course you can probably handle a little bit of offroad driving, but it's only 2wd. Do you know if you have a limited slip rear end? Meaning both tires spin and not just 1? If you don't have that, it may be something to look into. But good tires can certainly help. Cooper Discoverer STT is a good offroad tire with good street manners.
I'd paint the stock hood. You'll be hard pressed to find an aftermarket hood for the bricknose that isn't flimsy. But it's nearly impossible to find something like a cowl hood for it so like I said, keep your original one.
Typical maintenance is about the same with these as any vehicle.
Before you get all excited, Do the normal maintenance things. Oil/Filter, Lube, Check gear box, & all fluid levels. Does the tranny fluid smell burnt? Is it bright red or brown to black?
As for off roading its a two wheel drive. That said a good driver can go a lot farther in a 2wd that a poor driver can go in a 4x4. So how are your driving skills? Never go alone. Go with others that have 4x4s so if you get stuck they can help you get out. The only way to know for sure your driving skills & the trucks ability is to go out & do it. When you get stuck then you'll know.
Until you get all the maintenance done then worry about the hood. I would just repaint the hood you got, if it works OK.
But the main thing is to drive & enjoy it.
When I was 18 years old back in the caveman days we just drove them & fixed them when they quit. I have nightmares when I think back to the old junk vehicles we drove on bald tires pouring drain oil in the engine every 50 miles, & going like we had good sense. Travel hundreds of miles because I lived in the middle of nowhere in the high deserts of Nevada.
Craig
Craig
does the truck have an overdrive off button on the end of the shift lever, if it does it has an e40d, if the shift pattern is drive 2 1 and no button on the end its a c6, there is also an AOD, check the sticker on the side of the drivers pillar when you open the door and it will tell a ton of stuff about it. on the axle code if it has a letter in front of a number then its limited slip
As far as my driving skills, I haven't rolled it off a cliff or plowed into a minivan, but I'm young. The brutal winter gave me some experience and northern Missouri isn't particularly "rough terrain" anyhow. About maintainance, I've replaced the plugs, serpentine belt, wiring, battery, fuel system, oil, trans fluid, etc etc. about the trans it has P R N OD D 1 without any button on the lever. I didn't think they made the E4OD until like 92
What does your shift indicator read?
P R N OD D 1
Then likely it's an AOD.
If it's just P R N D 2 L
then it's a C6.
The 4rw and E4od both had P R N D 2 1 and OD was a button on the shifter handle.
The AOD loses 2nd gear on the shift lever. Makes a real PITA in winter time because you can't lock it into 2nd. Mine tends to search ALOT on slippery roads. Goes from lugging in D, to downshifting, then lug, then downshift. Really hate it.
P R N OD D 1
then it's a C6.
I'll check on the door jamb tonight and see what the stock trans is/was. In 1987 the only stock three speed they came with was the C6 and they didn't come with the AOD at all, so I can't imagine someone swapping out a C6 for an AOD. I try to count the gears when I'm driving and I'm pretty sure it's a 3+OD
