engine knock? - Ford Truck Enthusiasts Forums
engine knock?
Old 04-02-2013, 08:23 PM
barrett74 barrett74 is offline
barrett74 is starting off with a positive reputation.
engine knock?
Ok having a problem my engine sounds lik there's a knock when I'm accelerating it stops after I get to around 50-55 it sounds like its coming from the right side of the cab and I can definitely feel the knock in the gas pedal. Any ideas on what it would be would be helpful!
Old 04-02-2013, 09:10 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Can you make it " knock " sitting still ? Brake torque ? Accelerating in neutral ? If not , ck drive line , u joints , mounts , exaust . I had a noise drive me crazy for about a day , before I found a green Black Walnut stuck between the cab and the bed ! I swore it was in the exaust hangers or pipes . Sounds can travel .
Old 04-02-2013, 09:14 PM
JWC 3's Avatar
Oh , ck cab mounts also , they can let the cab fall and cause all kinds of complaints .
Old 04-02-2013, 09:57 PM
I haven't tried that yet ik jus sitting the engine sound fine ivI've thought about checking the exhaust manifold to see if its rusted out what in the engine could cause the knock?
Old 04-02-2013, 10:11 PM
JWC 3's Avatar
Because it seems to be related to the speed of your truck , not engine speed ,I think it may not be engine related . That is why I ask if you can reproduce the "knock" while stationary . On the other hand , many components can cause a knocking sound .
Old 04-02-2013, 10:24 PM
Oh ok you don't think it could be tranny related do you?? Maybe its first or second gear that's knocking somewhere??
Old 04-02-2013, 10:41 PM
Redmanbob's Avatar
Redmanbob Redmanbob is offline
Redmanbob is gaining momentum as a positive member of FTE.Redmanbob is gaining momentum as a positive member of FTE.
I think the advice is good, one option might be to take it to a smog test station if you have one local. They often have a wheel cart and could put it in motion sitting still so to speak. If the driveline is the issue. It would be easy to hear/see safely. Provided you stay away from reciprocating parts!! Listen with a stethoscope and extension if needed. If due to suspension or ? in front it would be absent, and it doesn't seem as that would be the case as explained.
Old 04-02-2013, 10:50 PM
JWC 3's Avatar
Quote:
Just so happens I have a Hino in the shop right now . It is a wrecker , rollback ,. It has a noise in the mixer . Mixers do not usually cause your complaint . Not what you describe , but possible . I would look further into the drive train for the knock . Less likely the mixer than other issues .
2.3 knock / pinging llangebartels Ranger & B-Series 1 08-15-2011 07:57 PM
Slight engine knock FxRiZBeAsTLy 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-31-2010 03:53 PM
Fuel Pump knock Kunami 1978 - 1996 Big Bronco 6 01-06-2005 01:03 AM
Lower engine knock? allen410 1987 - 1996 F150 & Larger F-Series Trucks 1 11-21-2004 12:52 AM
Knocking Sound? jkrez 1997 - 2003 F150 1 11-25-2000 12:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
