Front end updates for 2000 Excursion - Ford Truck Enthusiasts Forums
Old 04-02-2013, 08:21 PM
Expedition01 Expedition01 is offline
Expedition01 is starting off with a positive reputation.
Will the lamps and grille from an 02 to 04 SD bolt up and fit my 2000 Ex? Found a nice set on eBay.
Thanks.
Old 04-02-2013, 08:52 PM
garryk6's Avatar
garryk6 garryk6 is offline
garryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to behold
Yes they will fit.
But if you go for the 2005-2007 it could look like this!
Garry in AK
Old 04-02-2013, 09:53 PM
Looks great but I dont think those years will work with my bumper, hood, etc (or will it, if so I would go that route). I'm looking for some bolt on stuff for my 2000 limited. The stock Limited is a ittle to dressed up for me in front with the egg crate grille, etc. Looking for more a truck look
Will 02-04 stuff bolt on with the existing hood and bumper?
Old 04-02-2013, 10:12 PM
garryk6's Avatar
Yes, all the 2000 to 2004 will all interchange between truck and Excursion. The 2005-2007 truck stuff does require a bumper change, or a modification, thr lower portion of the grill can be cut off, or the bumper can be cut and welded and painted if you have access to those skills. One of the other guys here did the bumper cut trick. The grill cut is much easier for the one without those skills. The headlights will work from an 05-07, but requires an adapter for the plug, and some modification to the fiberglass header panel. If you search for 05 upgrade, there are many how-to's here.
Good luck, and welcome!
Garry in AK
Old 04-02-2013, 10:14 PM
Sorry I reread the note and you answered my question about 02-04 fitting onm the front end of my 2000
After seeing yours with the 2005 front end I'm really thinking about that instead. How much of a mod was that?
Thanks.
Old 04-03-2013, 02:08 AM
garryk6's Avatar
Well, I had the road armor bumper already, but the header panel will run you new between $100 and $150. Grill will be $150 to $200 aftermarket. RA Bumper will be about a grand. Many people offer kits to do it for $1200 with a stock bumper. Friends have done it for less via wrecking yard or Craigslist parts. I like to scrounge till I find what I like...
Hope this helps!
Garry
Old 04-03-2013, 07:00 PM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
BUY A NEW HEADER PANEL!!! Moding the OEM one is a pita!
Old 04-05-2013, 12:51 AM
xbox73 xbox73 is offline
xbox73 is gaining momentum as a positive member of FTE.
Similar FTE thread about headlights:
http://www.ford-trucks.com/forums/11...t-years-6.html
I had my local garage install the 02-04 Certifit replacements on my '00 X a couple of weeks ago. Initially, I though they might be too gaudy (which I was trying to avoid, I had purposely avoided all the over-the-top aftermarket options with multiple LEDs etc.), but in conjunction with the all clear L-shaped indicators & marker lights (installed by the previous owner), they actually look pretty good. The old lights were kind of a PITA to get out, but since my old lights were old & yellowed, I was going to chuck them anyway, so I think we might have ended up breaking one of the tabs on the old lens housing on one side to get it out. But anyway, the new 02-04 housing bolted right up pretty easily to the header panel on my '00 X. I tried to take a pic tonight with my phone, but the light was failing fast, so it came out pretty grainy & blurry. I'll take a better pic tomorrow, when it's light & post it up in the other thread.
Anyway, at least around town (I haven't taken them on a country B-road yet), I'm pretty happy with both the looks & performance of the newer '02-04 reflector style housing, in conjunction with an upgraded wiring harness from Susquehanna motorsports & PIAA 9007 Xtreme White Plus Bulbs (details in other linked thread).
Installing a newer dash in a 2000 f650 Jckcont Large Truck 6 12-07-2016 10:05 PM
2000 Ex - Oem Radio / Bluetooth BAJI26 Excursion - King of SUVs 1 09-19-2013 11:38 PM
Will a 94 ranger reg cab shell fit a 2000 ranger reg cab? jonwho Ranger & B-Series 3 11-02-2012 11:50 PM
2000 escalade manual? GrizzlyMan660 General Automotive Discussion 0 04-25-2012 12:51 PM
2000 Ranger hood ReBilld Ranger & B-Series 2 03-17-2012 05:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
