Fuel tank float repair - Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Old 04-02-2013, 08:09 PM
Pop's76's Avatar
Pop's76 Pop's76 is offline
Pop's76 is starting off with a positive reputation.
I discovered a crack about a quarter of an inch long in the float after I removed the sending unit from my tank. Has anyone ever tried to repair one of the brass floats? I have been contemplating trying to soldier the crack but I was worried about any fumes that might be inside the float causing the float to burst when heat is applied. I have a small propane torch but I think a soldering iron would work better as it would keep the heat isolated to just the spot needed repair.
Does anyone have any experience or opinions on whether or not this is worth an attempt? I can't find anyone locally that sells just the float and I do not want to spend $62 for the whole sending unit when all I need is the float.
Old 04-03-2013, 07:28 AM
Southern Bronco's Avatar
Southern Bronco Southern Bronco is offline
Southern Bronco is gaining momentum as a positive member of FTE.Southern Bronco is gaining momentum as a positive member of FTE.
Pop, I replace them whenever I need to drop the tank on one that has that style float, and they are less than $10 bucks from the dealer ship. Its good insurance.
Old 04-03-2013, 07:56 AM
ChiefM's Avatar
ChiefM ChiefM is offline
ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.ChiefM has a great reputation on FTE.
I agree with southern, I would just replace it. It blowing up is very small, especially if you soak it in water but for 10 bucks I would not even fool with it.
Old 04-03-2013, 04:56 PM
Pop's76's Avatar
Quote:
It would definitely be worth $10 if we had a competent dealership close by. The problem is the local ones have a bunch of idiots and teenagers in the parts departments and at the only good one within 60 miles the people in the parts department act like they would rather be bound, gagged, then shot than fool with you.The last time I went there it took 3 hours to buy 2 plastic clips that connect the heated hoses to the heater core in my 01 F150
Old 04-03-2013, 05:23 PM
Pop, PM sent
Holley 1904 float Rob68 1957 - 1960 F100 & Larger F-Series Trucks 4 02-20-2013 08:37 PM
Fuel sending units with plastic floats? fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-19-2013 01:09 PM
Fuel Sending Unit Mobro21 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 05-28-2011 04:55 PM
My Float has liquid in it... but it floats in H2o? turboguy 1987 - 1996 F150 & Larger F-Series Trucks 3 08-01-2005 06:44 PM
Need source for fuel sender float mshumack 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-12-2002 04:58 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
