2001 f150 want start
Could be several causes.
Battery, corroded cable terminals, start solenoid.
You have to begin to eliminate these one at a time to get to the cause.
What happens to the Theft light?
Is cranking at normal speed?
Do you hear the fuel pump run at key on for a couple seconds?
Every body dives for the fuel filter.
It won't be a cause for a 'sudden' no start.
What is the fuel pressure with a gage on the fuel rail?
Test by cycling the key to run several times.
Good luck.
Good luck.
Idaho Mtn Man
09-22-2012 09:35 PM
