The build of Balls deep - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 11-12-2013, 09:14 PM
mroth2008 mroth2008 is offline
mroth2008 is starting off with a positive reputation.
its custom I think idk I robbed it off a parts truck 2 years ago
  #32
Old 11-12-2013, 09:32 PM
GuitarJesus's Avatar
GuitarJesus GuitarJesus is offline
GuitarJesus is gaining momentum as a positive member of FTE.
Quote:
Damn I want a winch bumper like that. Good ones are north of $800
  #33
Old 11-15-2013, 03:54 PM
Ahhh yea that thing is heavyyy and with the I have for it the whole set up is close too 350lbs
  #34
Old 11-26-2013, 03:59 PM
Well started the tear down for the swap this winter for my 460.
  #35
Old 12-04-2013, 09:56 AM
Well pretty well I have the cab off now, should be pulling the engine this weekend hopefully after that the frame prep for the big block begins.
  #36
Old 12-05-2013, 01:42 AM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
Sweet rig! Love the bumper
  #37
Old 12-22-2013, 03:23 PM
Well havent made much progress on the truck I took the 460 to the machine shop. Got the 302 ready to pull and picked up anothe 460 with a 2 wheel drive 4 speed. And just picked up another truck a 1994 f250 extended cab long box 4x4 7.3 idi turbo auto, speedo, the windshield washer and rear tank sending unit dont work but other wise it was clean 231,600 kms on the truck, gonna turn in into the tow truck for ***** deep, runs awsome.
  #38
Old 12-30-2013, 07:37 PM
A 460 I bought for 60$ running 4 barrel.
And my tow truck for the 4x4
And mocking up a bush bar that was orginally on the 4x4
  #39
Old 12-31-2013, 11:51 AM
BriansCJ BriansCJ is offline
BriansCJ is starting off with a positive reputation.
I love trucks that get the **** beat out of them
  #40
Old 12-31-2013, 12:24 PM
joegeds joegeds is offline
joegeds is gaining momentum as a positive member of FTE.joegeds is gaining momentum as a positive member of FTE.
Anyway you can post more pics of the bumper? I think I could weld one up based on the pics already, but a few more for details would be great.
  #41
Old 12-31-2013, 08:40 PM
Its actually off a 1991 f250 with the 5.0. I can post of some pictures in the new year or just get one for free and make it fit or make your own.
Edit: Hhahah I thought you were asking about the new diesel one I got, I can get some more pictures of the bush bumper and a couple measurements its mostly just 10 inch C channel
  #42
Old 01-23-2014, 09:18 PM
Well got some more work done pulled the olde 5.0 engine transmission and transfer case as one unit Than splilt out of the truck like 1000 times easier but a lot more work gonna be worth it thou for the 460 swap.
And people thought I was crazy when I said I was gonna pull everything out as one in my backyard in the mudd. Was going to build my body lift tonight ended up helping a stranger on the side road, his maf crapped out wouldnt run, ironically truck on factory ignition still, did a tune up on the side of highway unplug maf and he could drive home. Hopefully this weekend I can get it made up, brothers picking up a sand blaster and I got air compressor free so gonna sand blast the frame instead of wire wheeling so untill that gonna do some other little things like rear bumper, body mounts, body repair, might roll cage it, if I have the time and 460 perches.
  #43
Old 01-27-2014, 08:43 PM
Well had the weekend off so I did some work on the truck primered the transmission and transfer case getting it ready for swapping in. And got the front 10,000lbs winch in the front stretched the cable out had 180 feet on the drum. Should run good, it runs off a pto on transmission, 18 gpm minium for operation but got a 38 gpm pump for it right now.
All the parts for the winch system pump, selector valve and tank. I do got an 1 1/4 npt filter head for it since the system orginally had no filter. Only down fall is thier has to be some form of body lift for the winch to clear the rad unfortunately but worth the huge drum it has, the winch is actully capable of 300 feet max of cable.
Almost making progress
  #44
Old 03-09-2014, 01:00 AM
Well progress has bein slow but it is progress, took my spare steering box apart drill and tapped for hydroassist, and took my steering box apart and did it too. Pulled my rear tank and it some tweaking, going to move the rear tank and putting my new 17,500lbs winch where the rear tank was and have its cable go through the rear bumper onto the roller, and mount the dual batteries right beside the winch for shortest length of cable possible. Pretty well built the mounting plate and some square tubing to mount to the frame, half way done the welding on the mounting.
  #45
Old 03-09-2014, 05:07 AM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
love the way the trucks coming out, nice work.
can you put up detailed pics an description of the winch to pto connection at the trans please ?
7.3 rebuild and hx40 mroth2008 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 11-24-2015 08:57 PM
high pinion 60 chris989 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-27-2014 03:14 PM
super cab vent windows chris989 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-02-2013 12:44 PM
help identify paint color chris989 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-05-2013 10:21 AM
September 2008 B/S Volume 5 glruff Maryland Chapter 314 09-17-2008 11:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
