The build of Balls deep - Page 2 - Ford Truck Enthusiasts Forums
Old 05-14-2013, 11:09 AM
mroth2008 mroth2008 is offline
mroth2008 is starting off with a positive reputation.
And I thought I would introduce the 460 Im rebuilding for this truck. Its a 1993 460 with fast burn bigger dish pistons came with headers, 5 speed and a hydraulic winch with pto. The only thing was everything was worn out so it pretty well needs a total rebuild and a good hot tanking since oil changes were an option.
Old 05-14-2013, 11:19 AM
So after modifying my 460 collectors at I went home and build a custom dual 2.5 exhaust no cats no mufflers straight pipe and she sounds mean heres a video of the exhaust a little tour and start up rev.
SAM_0709_zps770dfd16.mp4 Video by Mroth2008 | Photobucket
Old 05-21-2013, 04:22 PM
Well this weekend I moved most of my parts into my house moved my truck and camaro over. The truck dosnt run right now, it has terrible terrible fuel in it right now. The gas station denies having water in thier fuel of course and says its impossible. Right now I have tons of water in my fuel to the point where it just floods it with water so right now draining all my fuel out and putting new fuel in after and changing fuel filter since my was completely plugged. Hopefully I should get it back running tonight I know it will run if I shoot good gas down the intake to get it going after that you have to baby it just to get it idle.
Old 05-21-2013, 06:29 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Quote:
Water in the fuel is awesome. The last time I had that happen, I emptied all the fuel out of my tank into 5 gallon gas cans, and took them to the gas station and asked if I was going to get my money back, or if I was donating them to the managers fuel tank. I was refunded my money. A few weeks later, they had new tanks put in the ground.
Old 05-22-2013, 10:48 AM
Yea I drained about 20 ls of bad gas before it cleared up than drained another 10 to be sureput new filter in and she ran 100% put in some fresh gas should be good for awhile maybe.
Old 06-04-2013, 12:47 PM
Well bein awhile since Ive updated Ive bein mocking up traction bars. I've just about repaired my driverside floor plan and my dash is almost done need to wrap some more wires up and mount my heater up. I also decided to get rid of my camaro since the car has quite a bit of rot in it. So Ive bein stripping that, I went and checked out a 0 rust mustang but it has no engine trans and gas tank and has bein sitting for a year or more. But first I get to replace a window in my car since someone smashed the window stole my stereo, ironically the car was unlocked.......
Old 07-16-2013, 01:46 AM
Well took the truck out for its first test run this weekend, blew my rear driveshaft u joint straps. But the front axle works great I wheeled all weekend on front wheel drive and midd second day I lost my brakes but I went slowish I only hit one tree accidently. But I was flexing the truck out like a savage went over collapse bridges and washouts. The little 302 likes the headers and dual 2.5 exhaust and a new coil with 12 degrees of timing.
Old 11-07-2013, 10:05 AM
Well Id figured Id update the thread since I havent all summer since I have bein out playing with the truck. The truck took a beating for the whole summer grenade the factory transfer case destorying the whole case, blew a front driveshaft. Dialed in my rear traction bars, and but a locker in the front, picked up some new highsteer arms for the front. And some new second hand 44 inch boggers for the truck so now I need more lift and a sawzall. Like wise I prepped my zf5 205 combo for the 460 and put a 205 behind the mazda 5 speed. Hopefully this weekend I load some pictures up of the new rubber and all the fun the truck had.
Old 11-07-2013, 11:19 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown Bad Bad Leroy Brown is offline
Bad Bad Leroy Brown is starting off with a positive reputation.
Your truck is a freakin zombie! Just keeps on going...
Old 11-07-2013, 09:35 PM
87-XL-Squared's Avatar
87-XL-Squared 87-XL-Squared is offline
87-XL-Squared has a good reputation on FTE.87-XL-Squared has a good reputation on FTE.87-XL-Squared has a good reputation on FTE.
Keep us posted bud. I read the thread all the way from start to finish. Need more pics, like I told her: We love to look!
Old 11-12-2013, 01:56 AM
The truck is getting ready to go to sleep for the winter.
Old 11-12-2013, 02:48 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
I wonder if this link will work
Here is my little truck...
  #28
Old 11-12-2013, 10:17 AM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
very nice truck, makes me want to go have a bit o fun my self like that!!
  #29
Old 11-12-2013, 06:04 PM
Oh it great fun and your truck gets treated like mine ethier its 5500-6000rpm or idle (:. The whole in between isnt really needed
  #30
Old 11-12-2013, 09:54 PM
GuitarJesus's Avatar
GuitarJesus GuitarJesus is offline
GuitarJesus is gaining momentum as a positive member of FTE.
Dude that's a bada$$ front bumper. Do you know what manufacturer and model it is?
7.3 rebuild and hx40 mroth2008 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 11-24-2015 09:57 PM
super cab vent windows chris989 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-02-2013 01:44 PM
help identify paint color chris989 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-05-2013 11:21 AM
6 inch lift bump steer chris989 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-14-2013 03:33 PM
factory tow package, electric brakes? chris989 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-17-2013 08:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
