This morning my truck lost all power made it off the road check everything start back up made to work ran fine this afternoon drove home all good wound up having to go back to town same thing loss of power rev till it lost cam cleared up never a light one came on either time need help bad
When you say lost all power, does the engine stall/shut off or does it just idle? I know you mention starting it back up after looking things over, but just checking to get the whole picture.
Oil pressure good just put loop on last week fuel filter im not sure think I changed around 5 to 6k when this happens there is no lights come on and they do work
Reason: To add more info
I would pop the lid off the fuel filter and check to make sure it looks good. You can also pop open the drain line on the filter housing and see what comes out.
It only happens after the truck has warmed up? Like when the thermostat opens?
Check the fuel selector valve also. My truck did this a couple times before it wouldn't restart at all. Selector valve was stuck in the middle and or plugged up and couldn't get fuel. I couldn't even blow air back through the lines with an air compressor.
