Header help! EGR Questions!
Old 09-18-2015, 09:21 AM
1995F250351's Avatar
1995F250351
1995F250351 is offline
Hey everyone, I have my 95 F250 with 299500 km on the original engine... My EGR has failed and my o2 sensor has failed as well... Custom exhaust is now happening... Probably going to dump infront of both rear wheels. Here are the questions... I already have a set of Flowtech 12504... Will it be hard to take out the old exhaust bolts in my heads now? Going to go with Remflex 3003 gaskets cause they're by far the best... Question 2: my Egr is now open... There will now be a big hole in my intake?? I was looking for an EGR block off plate but can not find one anywhere.... Question 3 : will my code go away for my EGR valve? It is a stuck open code?
Old 09-18-2015, 05:19 PM
Conanski's Avatar
Conanski
Conanski is offline
You cannot delete EGR without setting codes, however you can disable it. To do that sandwich a piece of sheet metal between the valve and intake and then reconnect the vacuum line and sensor wires so that the valve goes through the motions as it should.
Old 09-18-2015, 05:40 PM
1995F250351
That being said, could I get rid of that long ugly tubr going to the valve from the manifold? And would It be a good idea to stick a gasket in between the intake and sheet metal?
Old 09-18-2015, 05:52 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
that's what hes saying above....
plug the ports with a penny sized piece of sheet metal...or other penny sized object....
Old 09-18-2015, 07:13 PM
1995F250351
Just to clarify... I meant the tube that was coming from the exhaust manifold
Old 09-18-2015, 09:50 PM
Conanski's Avatar
Conanski
Conanski is offline
Yes remove the tube that connects to the exhaust, it serves no purpose if the headers don't have a port for it, and yes use an extra gasket between the sheet metal(cut to the shape of the valve mounting flange) and valve and intake.
Old 07-19-2016, 02:40 AM
walperstyle's Avatar
walperstyle
walperstyle is offline
Update, pictures, video?
supramafia
1999 to 2016 Super Duty
08-24-2010 01:40 PM
strokin'_tatsch
03-10-2010 10:04 PM
jigman
15
03-01-2004 07:50 PM
CrazyFordMan
15
12-15-2003 09:01 AM
jimzettle
10-28-2003 12:05 PM
Quick Reply: Header help! EGR Questions!
