Tow Haul Mode - Ford Truck Enthusiasts Forums
Tow Haul Mode
Old 04-01-2013, 09:33 AM
Jumbo131's Avatar
Jumbo131 Jumbo131 is offline
Jumbo131 is gaining momentum as a positive member of FTE.
Tow Haul Mode
At what GCWR do you guys start using the tow haul mode? I have an F350 CC Dually FX4
Old 04-01-2013, 10:21 AM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
I used it this weekend towing my 5th wheel. I'm not sure what weight my total GCW is, but with the old truck it was right at 20k (probably close to the same with this one). I towed with the truck for the first time this weekend. I was impressed with tow/haul. I really liked the engine braking/downshifts while driving in traffic. I am thoroughly impressed with how the truck towed overall.
Old 04-01-2013, 10:53 AM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
I use it when I need it...completely doesn't answer your question, but that's an honest answer. If I'm towing a load that requires some help stopping (like a trailer without brakes or a heavy trailer), I'll use it. Any time I'm towing our enclosed four wheeler trailer unloaded, no, I won't use it. Loaded with wheelers, yes, I do use it. 5th wheel or loads over 7500 pounds are all the time. You will get a feel for when you use it and for me it is wanting the engine braking that will prompt me to use it.
Old 04-01-2013, 11:28 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
somewhat like savage - but I RARELY use it for any towing, even heavy on grades...
Will punch it on when I want to use the turbo backpressure to slow me down and save the brake pads for both the truck, and when towing, the 5th wheel... but turn it right back off as all it seems to do for me is make for more drama by staying in gear longer to higher rpms and eating up mpg ...
remember, our trucks have peak 800 lbft of torque at 1600 rpm, so high rpms are not tugging betta
IMHO, our trucks have enough oomph to pull without towhaul,
if it is straining without it, you are towing too much for the vehicle
consider a larger truck !
Old 04-01-2013, 11:42 AM
SavageNFS's Avatar
not a WHITE truck
Quote:
I'd agree with that for a stock truck...H&S fixes a lot of that crap if you use their tranny tuning
Old 04-01-2013, 11:53 AM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
If I hook up a trailer, I push the T/H button.
I find that it will hold the gears a little longer, Which I like if I'm passing thru a 25 mph speed limit, it stays in 2nd gear instead of upshifting to 3rd or 4th, then lugging when I ask for a little pick up in speed.
Anything I do. It could do in normal mode. But I like the shift points that the T/H uses when I have something hooked up. But then again, Everything I hook up is 10,000lbs or more.
Old 04-01-2013, 12:09 PM
Jumbo131's Avatar
Quote:
What's the issue with the trannies? I just bought a fw and weighs around 12k and only pulled it a short distance to get it home. What should I be looking for the tranny to do? Shifting in and out of gears to much, rough shifting, not shifting when it needs to?
Old 04-01-2013, 12:15 PM
SavageNFS's Avatar
not a WHITE truck
Quote:
The stock tranny is programmed to shift to the highest gear possible to keep the engine RPM's as low as possible. I assume for fuel economy and low engine noise. It works fine and is totally acceptable. H&S doesn't shift into higher gears all the time and holds gears when it makes sense to hold them. It doesn't shift until you need to shift and it's not uncommon to hold 2nd or 3rd gear running through a slow street or slow cruising through town. It's mainly personal preference, but I'd rather be in the right gear when I need more power rather than have to wait for the tranny to shift from 6th to 4th cause I'm ready to get up to highway speeds or whatever.
Old 04-01-2013, 03:28 PM
ForemanES's Avatar
ForemanES ForemanES is offline
ForemanES is gaining momentum as a positive member of FTE.ForemanES is gaining momentum as a positive member of FTE.
I'm with Painted Horse any trailer I engage tow/haul. Stupid little things like it automatically turning off the backup sensors are my reason even on the smallest of trailers.
Old 04-01-2013, 05:58 PM
rob92761's Avatar
rob92761 rob92761 is offline
rob92761 is starting off with a positive reputation.
i use tow/haul for light or empty trailers. Manual mode for heavey trailers. IMO i think the manual mode out performs the the tow/haul on these trucks.
Old 04-01-2013, 08:00 PM
whitewhale whitewhale is offline
whitewhale is starting off with a positive reputation.
hooked to a trailer, i'm in manual mode...come to think of it, I'm in manual mode with nothing hooked up also...
Old 04-01-2013, 08:34 PM
Munfrobie Munfrobie is offline
Munfrobie is starting off with a positive reputation.
I'm with PH. When I hook up I push T/H.
Old 04-01-2013, 08:46 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I use manual mode, a lot; towing or not.
If I'm on rolling hills, I set it to M5 and focus on driving.
In auto mode on hills, it's 6,5,6,5,6,5,6,5 and eventually irritates me.
Old 04-01-2013, 11:27 PM
Wrighton's Avatar
Wrighton Wrighton is offline
Wrighton is starting off with a positive reputation.
I use the T/H mode for pulling my 5th Wheel @ 12000 lbs, however my boat weighs 5500 and I see no need for T/H. When empty I will use manual to lock out 6th or 5th on very windy roads with hills where the trans shifts back and forth between 5 / 6.
Old 04-05-2013, 12:13 AM
His/Hers 6.0s's Avatar
His/Hers 6.0s His/Hers 6.0s is offline
His/Hers 6.0s is starting off with a positive reputation.
When hooked up to our 8Klb TT. Just took a 450 mile trip with our trailer and experimented both with and without Tow Haul Mode. My opinion: Put it in Tow Haul and forget it. Yea, it revs a bit more, but who cares? It does a great job mating the right gear for the demand at the time. The cab is quite that it's not a nuisance and the extra braking power when going downhill is great. Just think, there was an entire department full of very smart engineers choosing the algorithms programmed into this great truck and its all designed to work together. The engine and tranny in this one is far superior to my '04 F-350 6.0 PSD. I love it. No drama towing. Set it and forget it.
Tow-haul mode? lewis racing 6.0L Power Stroke Diesel 8 08-26-2014 01:35 PM
Tow haul mode Rod Jr. 6.0L Power Stroke Diesel 9 07-16-2013 08:19 PM
Tow/Haul Option lpbaca 6.0L Power Stroke Diesel 8 09-08-2005 07:49 PM
Should tow/haul always be used? dcbollinger Modular V10 (6.8l) 6 07-20-2005 08:16 AM
Tow/haul mode use JD Dixon 1999 to 2016 Super Duty 5 12-30-2004 10:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
