How can a plow not help? Just curious. You must have really hid that thing in there!
Well, kinda hard to describe. The camper is on the east side of my shed, between the driveway and shed. The front is about 6-8 feet back from the front of the shed and there is about 6 feet between the shed and camper. All the snow that slid off the roof is now between the camper and shed, just about to the wheel. I did plow it out months ago. Got as much as I could between the camper, shed, transformer and flower garden. Not too concerned with the snow, it's the soft ground in front of the camper.
Gotcha! Well then Saturday morning will be your best bet since the low is suppose to be in the teens the ground will be froze hard enough you shouldn't sink in.
Good thing I have the blocks in.....for extra clearance! I am not even sure my camper will fit thru the door opening yet? What a problem this snow causes!!!
You sure have all the answers. Excited a bit? You are goning to busy on Sat. helping everyone out. lol
Sure! I read it on the internet and it has to be true if it is on there!
I help where I can!
Well I have the answer for this as well it just so happens. Worst case is you have to let some air out of the tires on your truck or camper until you get it outside then use that handy air compressor we fixed up last summer and air the tires back up. Problem solved!
Well with the A/C unit when we bought it was 12' 2". We had them swap it out with a low profile unit and that one should have been 4" lower.......so if my math skills are any good it should be around 11'10".
