Questions About Flashes
2006 F-250 6.0
181,000mi
4690 ENG HRS
I have no clue what flashes this thing has had, is there any way to figure out what software is on it? Local dealer told me it could cost $500 to update the software, I was a little surprised.
At this point in time are the current flashes good to go? Worth $500?
Local dealership was in Cary/Raleigh NC Crossroads Ford.
181,000mi
4690 ENG HRS
Get someone with a Snap-on scanner and see what one you have.
this is what your looking for in the Global OBDII section of tests
<img src="http://imageshack.us/a/img11/3743/user00121103030059.jpg" alt="Image Hosted by ImageShack.us"/><br/>
Mine is the VXCF9H7.HEX that is the number your looking for.
From that you can see if you need or want a update it. Some are better than
others. It really depends on what you need. Post the info here and you will
be able to get some feedback on what you have.
Sean
Sean
The latest flashes give you the wrench light codes for over/underboost and coolant/oil temp delta's (maybe a few other things), and the inductive heating for the injectors in the FICM flash. I would shop around, I think $500 is quite high. Some think the latest flashes hurt fuel economy but with your truck being a 2006 they might actually help. If you run a tune the factory flashes are overwritten anyway, and the PHP FICM tunes have the inductive heating strategy, which I think is important for stiction control.
Brian
Brian
Sean
Sean
Hopefully sometime within the year or so. The hold up is actually GM vehicles as they have thousands of computer flashes and it makes for a huge mess when those vehicles ask for what computer they have.
Ford is pretty easy, but Chevy makes it difficult.
Josh
jaredlitch
10-15-2011 11:04 PM
