Southern folks please read. URGENT - Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: Archion
Old 03-31-2013, 09:46 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud of
Guy on our local 4x4 board was broken into last night. Hes in Louisa, Ky. Theres a reward out. If you hear/see anything PM me and ill get the info to him. Heres his post :
just found out my shop was cleaned out this morning someone pushed my jeep out from in front of the gate and pulled my truck from in front of the door and used my own car trailer to load up all of my shop and take it without a trace.
this is a partial list of what was taken
16 foot diamond brand car trailer with wood floor
ingersol rand 80gal/5hp upright air compressor
2 upright snap on tool boxes
snap on mig welder with argon tank
snap on stick welder
hydraulic bender
10 ton shop press with air of hydraulic cylinder
4 foot wide sand blast cabinet
oval 50 pound capacity sand blaster tank
bandsaw
smitthy latehe and milling machine
2 double door filing cabinet full of cams, paint guns lots of ring rod and main bearings
rod heater to press piston pins in
black and decker valve grinding resurfacing machine
oxy acelelyne tanks torches and hoses
snap on adjustable finnish hone with stones and wipers
4 - new 35x12,50-15 remington mud brutes
4 - 16.6x9.75 weld typhoon wheels 8 on 6.5 bp
454
4 engine stands
350 block fresh bore ready to assemble
all parts for 350 crank rods intake,
041x sbc heads full port in and out still in bags from machine shop with fresh guides and seats screw in studs and guide plates
dart iron eagle 215 kit - heads, matching single plane intake, valve covers 2.05 valves
3 sets BBC heads
sbc tunnel ram
bbc victor tunnel ram for 2 - 4500 dominator
bbc single plane built by cornet machine shop stamped on side 2" taller than regular single plane
dart team g single plane intake for 4500 dominator
sbc single plane strip dominator for 4150 holley
sbc single plane intake victor jr for 4150 holley
maybe 1/2 dozen other intakes
2 - 454 cranks
bbc cam - .647 solid roller
rev kit for sbc and bbc
6-8 sbc hydraulic cams
850 holley double pumper
3 - 750 holley carbs
2 - 650 holley carbs
1150 helley dominator
super t10 4 speed with fine spline output for 454 chevelle
ceramic headers 2" tubes BBC for chevelle
2 set of bbc truck headers one ceramoc one black
schoelfeild late model headers standard or brodix bolt pattern
6-8 micrometer from 1" to 6"
sbc and bbc stud girdles new in box
sbc and bbc master assembly gasket kits
2 metal tool carts
50 die cast cars and trucks i had saved when house burned the 15.00 ones from walmart and gas stations
cube refrigerator
305/50-15 slicks
new never powered moble home indoor furance
30 gal parts washer with safteykleen chemicals in it
unknown amount of rods and pistons
20 years worth of parts hoarding all gone will update list as i find more this is only what i can think of the big stuff
they even stole the rear wheel and tire off of my dads truck to put on trailer to change flat before they loaded up all my stuff and hauled it out on my own trailer
500.00 reward for information leading to arrest and prosecution
Old 04-01-2013, 07:54 AM
msgtg's Avatar
msgtg msgtg is offline
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Holy smokes! Thanks for being a good guy and sharing Cheeto!
Joe
shop broken into. crazyredneckanyhow Kentucky Chapter 1 03-31-2013 10:44 PM
pro street 65 f100 clarkw123 New Member Introductions 3 08-17-2005 10:45 AM
holley intake vacuum pageparsley Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 01-30-2005 07:52 PM
What A Sweet Sweet Sound. GHog Ford Inline Six, 200, 250, 4.9L / 300 34 12-29-2004 07:39 PM
ShaZam's New Truck Pulling Motor shazam Performance & General Engine Building 15 01-11-2002 11:12 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
