shop broken into.
on
1 Post
shop broken into.
Im posting this froma local board. This is from a member there. If anyone has an info PM me and ill get you in contact with him.There is a reward. His location is listed as louisa.
just found out my shop was cleaned out this morning someone pushed my jeep out from in front of the gate and pulled my truck from in front of the door and used my own car trailer to load up all of my shop and take it without a trace.
this is a partial list of what was taken
16 foot diamond brand car trailer with wood floor
ingersol rand 80gal/5hp upright air compressor
2 upright snap on tool boxes
snap on mig welder with argon tank
snap on stick welder
hydraulic bender
10 ton shop press with air of hydraulic cylinder
4 foot wide sand blast cabinet
oval 50 pound capacity sand blaster tank
bandsaw
smitthy latehe and milling machine
2 double door filing cabinet full of cams, paint guns lots of ring rod and main bearings
rod heater to press piston pins in
black and decker valve grinding resurfacing machine
oxy acelelyne tanks torches and hoses
snap on adjustable finnish hone with stones and wipers
4 - new 35x12,50-15 remington mud brutes
4 - 16.6x9.75 weld typhoon wheels 8 on 6.5 bp
454
4 engine stands
350 block fresh bore ready to assemble
all parts for 350 crank rods intake,
041x sbc heads full port in and out still in bags from machine shop with fresh guides and seats screw in studs and guide plates
dart iron eagle 215 kit - heads, matching single plane intake, valve covers 2.05 valves
3 sets BBC heads
sbc tunnel ram
bbc victor tunnel ram for 2 - 4500 dominator
bbc single plane built by cornet machine shop stamped on side 2" taller than regular single plane
dart team g single plane intake for 4500 dominator
sbc single plane strip dominator for 4150 holley
sbc single plane intake victor jr for 4150 holley
maybe 1/2 dozen other intakes
2 - 454 cranks
bbc cam - .647 solid roller
rev kit for sbc and bbc
6-8 sbc hydraulic cams
850 holley double pumper
3 - 750 holley carbs
2 - 650 holley carbs
1150 helley dominator
super t10 4 speed with fine spline output for 454 chevelle
ceramic headers 2" tubes BBC for chevelle
2 set of bbc truck headers one ceramoc one black
schoelfeild late model headers standard or brodix bolt pattern
6-8 micrometer from 1" to 6"
sbc and bbc stud girdles new in box
sbc and bbc master assembly gasket kits
2 metal tool carts
50 die cast cars and trucks i had saved when house burned the 15.00 ones from walmart and gas stations
cube refrigerator
305/50-15 slicks
new never powered moble home indoor furance
30 gal parts washer with safteykleen chemicals in it
unknown amount of rods and pistons
20 years worth of parts hoarding all gone will update list as i find more this is only what i can think of the big stuff
they even stole the rear wheel and tire off of my dads truck to put on trailer to change flat before they loaded up all my stuff and hauled it out on my own trailer
500.00 reward for information leading to arrest and prosecution
hydraulic bender
bandsaw
454
4 engine stands
3 sets BBC heads
sbc tunnel ram
2 - 454 cranks
2 metal tool carts
cube refrigerator
305/50-15 slicks
I would talk to the local tool guys, Mac, Snap-On, and I know there's a guy selling S&K Tools around there too, as well as all the shops around that I could. I'd be curious if the cops are investigating this. There's some shops on the other side of the river there too. The folks that stole this will likely get pretty far from there to sell their stuff, but it never hurts to ask around.
I was robbed in Prestonsburg a few years ago while staying at a hotel. Someone stole all of my welding leads. I just don't know how much investigating is ever done when this happens.
ScottInTexas
09-29-2007 05:43 AM
craigl58
04-01-2006 03:06 PM
I_Thnk_Ford
05-06-2003 07:03 AM
