4" rear block?
Old 03-31-2013, 08:33 AM
RKraft's Avatar
RKraft
RKraft is offline
4" rear block?
Sorry to bring this up if it has been posted before. My question is this I found a set of used 4" rear blocks that the owner is replacing with the 2" for towing his 5th wheel camper. He is gave me the part #'s of his blocks of 2C34-5598-FA & 2C34-5598-GA & also gave me these #'s F81Z-5598-FA & F81Z-5598-GA. I know the second set of numbers are correct but not sure if they replaced the actual numbers on the blocks them selves. I am starting to get everything for V/B swap & figured if I can get blocks used & safe a few bucks why not I'm on budget as it is.
Thank you,
Randy
Old 03-31-2013, 09:08 AM
acf6's Avatar
acf6
acf6 is offline
If they're just under 4" high and from a 99+ F350, you've got the right block
Old 03-31-2013, 09:41 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
X2! If you use the 4" block, you don't need to mod the Bs. Just put them on the way they come.
Old 03-31-2013, 09:44 AM
RKraft's Avatar
RKraft
RKraft is offline
Cool Thanks for replies. They are from an 06 F250 just wasn't sure if they were the same since different part numbers.
Randy
jav_eee
1999 to 2016 Super Duty
12-10-2017 12:57 PM
ZooDad
6.7L Power Stroke Diesel
06-02-2016 10:55 AM
jasonch
12-20-2011 01:33 AM
Ranger 620
11-09-2010 05:28 PM
Quick Reply: 4" rear block?
