CAN bus bulbs?
CAN bus bulbs?
I'm wanting to change over my tail/turn signal lights over to LED, since I'm going to tint the lens.
I know I need a 3157K bulb to replace the stock one.
I went to superbrightleds, and pulled up this,3157 CAN Bus LED Bulb - Dual Intensity 26 SMD LED Tower | 2004 Ford Ranger Stop Light LED Replacement Bulbs | LED Brake Light, Turn Light and Tail Light Bulbs | LED Car Bulbs | Super Bright LEDs
No where does it say this will replace the stock bulb. Maybe I'm not sure what the "K" designation means, or what this "CAN bus" stuff is.
Anyone offer some "inSIGHT" on this?
The K = Kelvin, or the color temp spectrum of the light & the number 3157 = the temperture of the lamps filament, or the color of the spectrum of light its emitting, or in the case of an LED, the color spectrum its emitting.
For instance, home incandescent light bulbs typically operate at a lower filament temp of about 2850K, so they're white light is sorta yellow tinted compared to the higher color temp of a 3157K lamp, or LED whos color would appear more blue tinted.
CAN = Controller Area Network
Ya, the turn signals did hyperflash, but I took care of that by installing an EP27 flasher.
I ordered the CAN bus type bulbs, then found out they shouldn't be used on a non CAN bus vehicle. Took a little to find that a Ranger is non CAN bus, so returned them to superbrightleds, and ordered the right ones.
I'm not sure why you shouldn't, it's just what they stated.
choate
01-16-2015 05:00 PM
