77 F250 HighBoy Steering - Ford Truck Enthusiasts Forums
Old 06-03-2003, 09:23 PM
Johnnyred_2003 Johnnyred_2003 is offline
Johnnyred_2003 is starting off with a positive reputation.
Question 77 F250 HighBoy Steering
I have a 77 F250 High Boy which I just swapped in a rebuilt 400. Runs great, I have power assist steering, but it is intermittent. it's easy, then hard, then easy, then hard. I am not sure if I should bleed the system or put in a rebuilt unit. Has anyone experienced this or done a power steering swap?
Thanks,
Old 06-03-2003, 09:29 PM
superswamper's Avatar
superswamper superswamper is offline
superswamper is gaining momentum as a positive member of FTE.superswamper is gaining momentum as a positive member of FTE.
probably just need to bleed the system would be my guess just like a bubble in a hydrolic clutch line
Old 06-03-2003, 11:08 PM
gregdatech gregdatech is offline
gregdatech is starting off with a positive reputation.
if theres play in the steering before the pitman arm, then it can cause problems too. Mine has a sloppy column, and does exactly that.
Old 06-09-2003, 12:52 PM
Tony150 Tony150 is offline
Tony150 is starting off with a positive reputation.
You can get air out of the system by making sure the reservoir is full and then turning the steering back and forth to the stops several times with the truck running. Be careful not to hold the steering at the stops for any extended time as this may damage the Gearbox/pump.
Also recommend checking any U-joints in the steering shaft for looseness and/or binding. Notorious for steering problems.
Tony C.
Old 06-09-2003, 02:04 PM
Quote:
Dod you replace the column? How did you fix it? Appreciate all the responses.
Old 06-09-2003, 07:15 PM
I havent replaced my column yet. I have a cab that Im going to drop on my frame, whenver I get some more money. From there, Ill probably replace it with a Borgeson unit.
Old 06-10-2003, 03:51 PM
78f3504x4's Avatar
78f3504x4 78f3504x4 is offline
78f3504x4 is starting off with a positive reputation.
I have p/s conversion info.
Steve
Old 06-10-2003, 04:08 PM
Steve,
I will send you an E-Mail.
Thanks,
John
Old 06-10-2003, 04:17 PM
okiebronco's Avatar
okiebronco okiebronco is offline
okiebronco is starting off with a positive reputation.
be sure to raise teh front tires off the ground when you are bleading the steering system. i dotn remember why but i remember its a good thing to do lol
Old 06-10-2003, 05:14 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Steve
Is there any reason why you won't just post it here?
Old 06-10-2003, 05:20 PM
Steve has been very helpful, and responded immediately. I am sure that he will post the info as he was very helpful and gave me the info. He is a true Ford Truck Enthusiast!
Old 06-12-2003, 08:13 PM
stewdozer's Avatar
stewdozer stewdozer is offline
stewdozer is starting off with a positive reputation.
I did a power steering conversion on my '74 highboy about 16 years ago. The kit was from a guy in Iowa named Scott Ibeling. It uses a 73-79 2wd power box that can be cheap to find. Simple setup that works excellent and has more clearance at the drag link side for wide tires. My dad bought this truck new and the power steering was junk from day one, it used to get so stiff in our Minnesota winters that he cracked the steering wheel trying to turn it. I can post the kit info if anyone's interested.
Old 06-12-2003, 08:39 PM
78f3504x4's Avatar
Not sure if I can post phone numbers here, but I will anyway. Ibeling Repair Service (319)347-2491. Scott knows everything about power steering, and has made these kits for 20 years! I have a 71F1004x4 and a 68F2504x4 both with the kits. Worth every penny.
77 351m swap to a FE Raider50 Engine Swaps 4 05-02-2014 10:52 PM
78/79 Steering box mount 64rarebird 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-09-2014 07:57 PM
Highboy question? 74fordhighboy 1973 - 1979 F-100 & Larger F-Series Trucks 12 05-20-2010 02:25 PM
How hard to change steering on 78 F250? 69BigblockFord 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-09-2007 10:54 PM
steering column swap ? sasgc69 1967 - 1972 F-100 & Larger F-Series Trucks 7 11-11-2002 09:44 PM
Tags
74, cage, conversions, f250, ford, frame, highboy, ibeling, kit, power, problems, repair, roll, scott, steering, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
