Newbie 302 // Mustang II // Rear sump?
ok guys.. I've been lurking around for a while. I need some help. I have a 1950 F1 that we have replaced the stock front end with a TCI Mustang II. The truck already has a small block ford that my father and his buddies put in it before my dad passed. I have the truck now and am slowly making some changes to it.
I found the motor code c80e 6015a today on the block and it appears it is a 1968 302.
Evidently I have to change the oil pan to a rear sump. Do any of you guys have this same set up? Can you make recommendations of which oil pan to buy?
I found this one on Summitt's site but it appears to be for a different year small block......
Ford Racing Engine Swap Oil Pan Kits M-6675-A50 - SummitRacing.com
Thanks !!
Thanks !!
One of the guys in my truck club did a rear sump pan swap . The vans had a rear sump pan . I had to go to junk yard and pull engine high enough to get pan off to get a special main cap bolt that has a stud in the center for the bracket of the sump that comes all the the way from front oil pump to rear.. Took me 4 hours WHEW He had bought crome oil pan from a place like Jes or Summit. ....Dude
Hey TMC,
Welcome Aboard! Nice to see another 1950 on here. We put a 351W in our's so I'm not sure the pan would be the same. You should be able to find one on Summit. If you have a pic your post will generate more attention.
Tell us a little more about your build plan when you get a chance.
Ben in Austin
1950 F1 (351W/AOD)
Ben in Austin
1950 F1 (351W/AOD)
Thanks for the info guys.
Ben, I've found a few that may work but trying to keep the budget as low as possible.
The truck was a daily driver before my dad passed. He paid a guy to change the front end to something with power steering. The guy working on the truck jacked the job up and then almost died from a medical condition. My dad went to get his truck and brought on home on a trailer. This crushed my dad as his health was failing so he sold the truck a week later because he could not fix it. It took me 7 years to buy it back and has been in my garage for year or so before I started working on it. At this point it is a 302 with a C4 which I plan to keep. We have cranked the motor and then pulled the drive train out and started body work. I do have a few pics and will try to post some shortly.
Thanks !!
Thanks !!
This pan fits extremely well! All aluminum, go to your local yards and find one.
That might cost you $25 bucks. don't forget the oil pickup tube that goes with it. Just thought though...'68 302 is probably a rope type rear main seal and these are a one piece rear main rubber seal....may not work on your motor...
This is mine. "96 Explorer 5.0 found in 2-wheel drive and all wheel drive. NOT 4-wheel drive. 4-wd didnt have 5.0\302
Thats good info! I didn't know that about the oil pans on the explorers/mountaineers. Back when I went to the junk yard to get my gt40p heads off of a mercury mountaineer, I should have gotten the oil pan too, that would have save someone some cash lol. I know I spent about $100 on a new oil pan setup
Tat2ed64f100
11-06-2008 08:29 PM
sancochojoe
05-03-2005 02:52 PM
mwilson
13
07-22-2003 03:51 PM
