Looking for this '48 F3 &/or Info...
#166
A few more questions....
• The speedometer works, but it's way behind the curve. How would I go about fixing that?
• Fuel gage works, but it's also showing 1/4 tank when it's full, how do you fix that?
• What do the original tail lights look like and where are they mounted?
• What do I need to know about replacing the wood bed?
• Ignition key bezel, where can I find one?
• Tires.... 7.00x16, seem to be hard to find. Can I use 7.50x16? I want to use regular tires up front an mud tires on the back.
• Straight pipes or muffler?
• Water pump squeaks, is that normal? Is there a lube point on them?
• Radiator looks rough, but holds water and pressure, should I replace it or wait?
#172
Fuel Gauge - Check the float on the sending unit - these things can deteriorate over time. Replacements are available. You'll need to remove the sending unit and extract the arm and attached float from the tank to inspect it.
Tail lights - they attach to captured nuts on the side of the bed/tailgate area. There are brackets from LMC and others needed to hold the lights in place. The driver's side bracket would also hold the license plate and the tail light will have a white down lens to illuminate the plate. Locations are shown:
Haven't found a source for any ignition parts - watch eBay.
700 x 16 tires are available from Coker Tire
Straight pipes / Muffler - what's your tolerance for cabin noise?
If the water pumps are squeaking - you should plan to rebuild / replace.
Unless you've had the radiator acid dipped, you don't know the real condition. If you like the excitement of uncertainty, wait for it to fail. Otherwise, have it cleaned at a radiator shop.
DW
#176
#177
#178
