Adjustable camber bushings - Ford Truck Enthusiasts Forums
Old 03-30-2013, 08:07 PM
Jarryd's Avatar
Jarryd Jarryd is offline
Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.
How hard are these to install? Is there a how to somewhere? I put in my leveling kit thinking I could get it somewhat close and its way off so I need to get these now. My mistake for not planning ahead.
Old 03-30-2013, 08:11 PM
Jarryd's Avatar
Also, where is the best place to get what I need?
Old 03-31-2013, 09:47 AM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
Pretty easy install. Remove upper ball joint nut, remove camber sleeve that's currently in there, install adjustable sleeve. Sometimes the sleeves are a pita to get out. It'd probably help to spray penetrating fluid on them for a couple days before you're doing the job.
There should be a chart with your new camber sleeves that outlines what number/letter to set them at to get zero degrees. Install them at zero, check the camber angle with an angle finder, then set the bushings where you need them. Use plenty of anti-seize when you install them.
I got mine at Rock Auto.
Old 03-31-2013, 10:48 AM
Jarryd's Avatar
There were several different ones on rock auto. Which ones should I get?
Old 03-31-2013, 11:25 AM
Jarryd's Avatar
I just need the part number for which one to order on my rwd truck. I'm not concerned with the alignment being perfect, just close enough that the wheels aren't tilted. I'll get it aligned right when I get new tires.
Old 03-31-2013, 12:33 PM
Quote:
What year, model, 4wd or 2wd?
Old 03-31-2013, 12:37 PM
Jarryd's Avatar
94 f150 rwd
Old 03-31-2013, 12:44 PM
Moog K80109 are the ones you want.
Old 03-31-2013, 01:24 PM
Jarryd's Avatar
Does it come with both of them or do I need to order 2?
Old 03-31-2013, 04:14 PM
Order two of them.
Old 03-31-2013, 06:44 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
You are wasting time and $ doing this. Just take it to a alignment shop that can do it. Just lifting it some will throw the camber out but the toe should stay close. Change the ca.ber bushings and you toe goes way out... That will eat tires.
Old 03-31-2013, 08:02 PM
Jarryd's Avatar
I have to adjust my camber before I do anything but then I'll take it in to get the alignment done. I don't think setting it up to be straight is ever a waste of money.
Old 04-01-2013, 07:23 AM
bashby's Avatar
What about the caster? Everyone seems to think you put the adjustable bushings in then turn them to get the camber right... doesnt work that way. I have done hundreds of alignments with camber bushings in these trucks. You need to get your caster and camber readings, then remove the old bushings, see what offset they are, calculate which bushing to put in or how to orient the adjustable one, then hook the machine back up to verify caster and camber then set the toe. I woould be pissed if someone put those adjustable ones in then brought it to me. they are nearly impossible to get out without destroying them. I prefer the fixed bushing of the correct offset. They cost a lot less also.
Old 04-01-2013, 08:12 AM
Quote:
If alignment shops had bushings in stock, or readily available at parts stores, I agree with fixed bushings 100%. However, at least in my neck of the woods, it's tough to find an alignment shop that's willing to set more than toe on these trucks, let alone have bushings readily available to set camber.
Proper procedure, per Ford, is to remove factory bushings, install zero degree bushings, then calculate what you need. Which is why, when I did mine, I set the adjustable bushing to zero, calculated via the chart included with the adjustable bushings, set the bushings, and installed them. Toe was roughly set, by me, then dialed in at the alignment shop. Took them all of a half hour to fine tune toe, and they actually thanked me for saving them the trouble of messing with the camber.
No matter how it's done, changing camber is going to affect toe, and changing toe (if it's way out) will affect camber.
To the OP, perhaps it's worth a call to your local alignment shop to see what they can do for you, and what their recommendations are about parts.
Old 04-01-2013, 08:36 AM
Jarryd's Avatar
That may be a good idea. Just trying not to spend too much to get it straight.
Avatar How To BlueOvalFitter User Gallery & Picture Display 0 11-28-2012 03:18 PM
How to remove wiper knob? 1974 F100 HareBall 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-20-2007 12:16 AM
albums, how to update?? 18vtx00 User Gallery & Picture Display 2 07-08-2005 10:52 PM
cd dj error shess62 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 10-02-2003 12:15 AM
anyone know how to build a wood flatbed for 78 f-100 cherokee 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-05-2003 04:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
