Shift on fly quit
Alright, so we go upstream now.
Backprobe the 4x4 module at the BRN/WHT and the ORG/LT BLU (these are your lo-hi and hi-lo command outputs). Do you have power when turning the switch?
If yes, then you have a short between the relays and the 4x4 module.
If no, pull your switch out. Do you have power at the WHT/LT BLU wire? (this is your ref. voltage feed. It should be ~5v. DO NOT USE A TEST LIGHT ON THIS WIRE)
If yes, do you have a voltage drop across the WHT/LT BLU and DK BLU wires? (Red lead on WHT/LT BLU, black lead on DK BLU) In the three positions there should be a different voltage drop at each position.
If you don't have power at WHT/LT BLU, backprobe 4x4 module at WHT/LT BLU (DO NOT USE TEST LIGHT) do you have 5v?
I'll check in later
I'll check in later
I'll check in later
I'll check in later
No power at the module, power to Wht/Blu wire not much voltage drop on DK Blu wire when turning switch.
Well, it is not the switch or the relays for sure, Dealer didn't have the module, it will be here tomorrow. Frequent customer so got to try not buy,,,shewww
#29
#30
Received 3,102 Likes
on
