1993 F250 bad PCM? Symptoms - Page 2 - Ford Truck Enthusiasts Forums
Old 08-02-2014, 03:26 AM
Billy nilly Billy nilly is offline
Billy nilly is starting off with a positive reputation.
I know this is an old thread but I'm having the same problem with my 1994 van with the 351 in it. th
Quote:
Originally Posted by Lead Head View Post
A chattering PCM relay, or one that does not make a complete connection can prevent the processor in the computer from starting up. If the processor doesn't start, the fuel pump keeps running.
The relays cost next to nothing, and it's a good place to start rather than dropping $150 on a new computer.
My fuel pump runs continue when the check engine light comes on it wants to take off in second gear ,blowes black smoke, neutral drops its self at 70 mph with the cruise set. Ya wow is an understated pcm mabe?
Old 08-02-2014, 11:17 AM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Please make a new thread, as your problems are a bit different.
Possible PCM Issue??? MKLC 1987 - 1996 F150 & Larger F-Series Trucks 44 03-31-2016 07:26 PM
KOEO 111, CM codes 332, 628 & 634 subford 1987 - 1996 F150 & Larger F-Series Trucks 2 10-18-2015 11:20 AM
2015 f350 regen issues badgeking 6.7L Power Stroke Diesel 22 09-21-2015 01:02 AM
Bad PCM? JoePeeper 1987 - 1996 F150 & Larger F-Series Trucks 4 10-29-2013 02:42 PM
E4OD without 3rd or OD NM3 1987 - 1996 F150 & Larger F-Series Trucks 4 05-23-2013 10:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
