97 7.3 front engine bracket problem - Page 2 - Ford Truck Enthusiasts Forums
Old 04-01-2013, 01:24 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
zthayer, let me know if you need that bracket I have one I could part with.
Old 04-01-2013, 01:56 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Quote:
I have a spare as well, I'd have to look it over a bit closer but it appears to be in good shape.
Old 04-01-2013, 06:03 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.
After you replace the bracket, watch the belt to see if it bounces on the tensioner. A bearing on one of the accessories could be failing. Just a thought.
Old 04-02-2013, 05:41 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
That bracket on my '96 failed when it was 6 years old, probably only had 60k miles on it. No idea why, but it happended when I was 5 minutes from home when the day before I was 2 hours away. All of a sudden I lost brakes and steering. Pulled over and saw belt was still there but everything was loose. I pulled the belt off and just drove home watching the coolent temp climb a little.
At the time I opted to get a new one from Ford as I couldn't find a used one (back in '02, not too many people on the boards back then with these parts) and it was pricey. I have since talked with several welders who say there's no problem welding it up.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
Old 04-02-2013, 06:50 AM
It kind of makes you wonder if they didn't just get some bad castings....
Old 08-09-2014, 03:09 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Bringing this thread from the dead…mine just broke this morning. The bolt that goes through the bracket and threads into the pump broke, overloading the casting at the other two bolt locations. New bracket will cost two and a half. Ouch. Fords parts guy gave me the same part number given in earlier posts. I found the bolt head in the driveway this morning but it didn't click what it was from. I had to cut some hardware from the truck recently and this looked about the same size and I just shrugged it off. Note to self, don't discount the importance of a random piece of hardware in your driveway.
Old 08-09-2014, 08:19 PM
quesey's Avatar
quesey quesey is offline
quesey is gaining momentum as a positive member of FTE.
If you need 1 PM me on it I have a couple extra
But I'm out of town till Friday
Old 08-10-2014, 03:08 PM
LeoJr's Avatar
I sure appreciate the offer! If I had a little more time I'd wait, but I just don't. If you are interested in selling one I might keep it on hand to ensure I never need one again.
Old 08-10-2014, 03:09 PM
LeoJr's Avatar
Laid a 2x4 onto folded rags on each fender, removed the 4 bolts holding the AC pump and tied it up with wire so the lines would be moved as little as possible. This also made for a helpful arm rest and leaning point. Removed the vacuum pump and the bracket in this picture. I guess I'll change the power steering pump, it has 170k miles on it, and it will never get any easier than now to do so as I have to pull the pulley to put on the new bracket.
Broken bracket. With the inner bolt snapping, and the pull of the belt and resistance of the pump pry the pump body away from the bracket putting a bending force into the bracket. This seems to be the only bolt that is under tension. I'll go back with grade 8 bolts, and will torque this one bolt to the low end of the recommended value and use loctite on all three.
NewDay, NewProblem. 94 E350 Belt. Gone through 5 in the last 14hrs. Resendiz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 10-14-2016 02:20 PM
CVF Racing pulleys & PS brackets for FE Engines- Anybody using 'em? HIO Silver 1967 - 1972 F-100 & Larger F-Series Trucks 12 06-21-2015 08:24 PM
power steering bracket raven3 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-01-2014 08:10 AM
Crank pulley...and others? hillcogolfer Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 03-15-2014 11:22 AM
Help planning Power Steering Pump for 223" BurnerDoc 1957 - 1960 F100 & Larger F-Series Trucks 2 01-26-2014 03:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
