1978 - 1996 Big Bronco
Door striker question
Old 03-29-2013, 06:17 PM
dieselbronc's Avatar
dieselbronc
dieselbronc is offline
My 86 Bronco has a large washer that comes off with the striker pin ,how does one get the nylon sleve on the striker?
Old 03-29-2013, 07:42 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
If it's like my 93, you don't, you replace the whole thing, or at least it was like that before, maybe there are nylon inserts available now... If the washer can't just go over the threaded part of the striker you'll need to make a longitudinal cut on the nylon insert and then slide it over the pin.
Old 03-29-2013, 08:39 PM
dieselbronc
I thought of that but I was thinkin it may come off
Old 03-29-2013, 09:50 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
The washer probably doesn't. I think mine is the same, as encho said, just cut the new one and slip it on. Maybe run a lighter over the cut part to try melting it back together?
Old 03-30-2013, 06:17 AM
b4hntn's Avatar
b4hntn
b4hntn is offline
The washers on mine unscrew.
Old 03-30-2013, 08:25 AM
scott79's Avatar
scott79
scott79 is offline
All of the 78-96 bronco door striker bolts are designed to be able to unscrew the washer from the bolt and replace the nylon bushings. But, if its been over-tightened or has some rust this might be hard to remove. Just use some PB blaster, let it soak for a few hours. You might also need to some tools to remove the washer from the bolt, but it does come off.
Old 03-30-2013, 11:47 AM
GruesomeJeans
Oh, weird. Well thanks for the info.
f100today
03-31-2017 07:09 AM
jimrdrnr
04-10-2010 10:09 AM
Old Dog 2
08-24-2008 06:42 PM
packing tractor
09-18-2006 11:35 AM
Quick Reply: Door striker question
