External Transmission Filter question
Ok. I'm not adding this one to my build thread, as it's just a question, but I came across dieselsite.com, and they offer a bunch of cool aftermarket options at decent prices for the 94-97 7.3's.
And I found this. https://www.dieselsite.com/dieselsit...4-199773l.aspx
Will this:
1.) work on our trucks
2.) has anyone seen something like this before if so...
a.) how effective is it
b.) is it worth it
c.) does it really extend the life of your transmission?
There aren't a lot of modifications like this floating around, and they appear to make a lot of this stuff themselves, that is practical and not wallet busting. I haven't got to my transmission yet, but when I do, would this be something to look into? Or should I just contact them for more information regarding this?
Will this:
b.) is it worth it
Do you have a link for a good site to get that particular filter from?
Did you notice any difference in the transmission after the install? How often do you replace the filter, and was the install fairly easy?(I'd be interested to see the inside of the filter after it's replaced)
For the price, I wouldn't mind getting that, I'm probably due for a transmission oil change, gasket and filter anyway, If it looks bad, I'll probably get it. Just one more thing to keep the truck parts running longer.
Either way, I keep finding myself drawn to that site. Pretty d@mn innovative if you ask me. lots of stuff you won't find anywhere else. Stickers are definitely going up on the back glass
I'm talking about a auto, are you? I couldn't tell any difference in the trans and the filter I got from dieselsite I got the optional gauge with it so I could tell when the filter needed changed. Its a easy install, disconnect the rear line and use the lines that come with it.
Anyway, the manual transmission, the 94 7.3 PS was a manual transmission only. Guess I'll get under there tomorrow and find out. If I see lines coming out of the transmission to the radiator, I'll take a wild guess and say it was for a transmission cooler, and has an internal pump? That, or check my supplement manuals if all else fails, take a the serial off it, and throw into google.
According to the data plate on the door, Truck was manufactured in 8/94. If that helps.
Tranny type would have been a good thing to mention on opening; there isn't even a mention of the tranny in your build thread.
No. The ZF6 that went into the Super Duty trucks have an internal pump and an option for an external cooler and/or filter. It's an extreme rarity in manual transmissions. There's a reference to that in the dieselsite listing.
Uploading a picture to my build thread, I have what looks like a broken transmission oil pan..
The primary filter is still there doing it's job. My thoughts would be if the magnafine clogs, you've either not changed it in several hundred thousand miles, or you're already screwed anyway because something's coming apart in there.
If the transmission did have an internal pump, where would the lines come out? or is there a plug where the external filter could be mounted?
I'm due for a change of filter and pan anyway, I just can't for the life of me, find the transmission oil dipstick or where to fill it.. And I was all under the truck today, guess the appearance of the broken flywheel inspection dust cover threw me off my primary goal.
Will this:
b.) is it worth it
Will this:
b.) is it worth it
Jeff
I'd run the Magnafine filter abt $15.00 and good for about 15,000 miles. I run the magnafine on my E99. I now have 265,000 miles on the transmission and receive excellent oil reports back from Blackstone. I do use the truck to haul a cabover camper and pull a gooseneck horse trailer. So far, no transmission repairs...Just fluid and filters.
Jeff
Jeff
