Stock transfer case shifter for 1967 -1972
Old 03-29-2013, 07:18 AM
Bad 674x4's Avatar
Bad 674x4
Bad 674x4 is offline
Is the 1966-1977 Bronco's transfer case shifter the same for the 1967-1972 ford trucks? I need one .
Old 03-29-2013, 12:09 PM
RichS2659's Avatar
RichS2659
RichS2659 is offline
Bronco uses a Dana 20 TC, F-100 uses a single speed Dana 21, F-250 uses a Dana 24. The shifter won't fit, unless you can fabricate something. IIRC, you are using a 92 chassis, so you have a Borg-Warner 1356, so it won't bolt-on either. You will have to fabricate a shift linkage. If you want a stock looking 67-72 rod shifter, strip the rubber and plastic off your existing one, and get an old shifter ****, and mount it if the shift patterns are the same.
Old 03-29-2013, 03:18 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Not the same.
C7TZ-7210-V .. T/C Shift Lever - 1967/72 F100 4WD / Obsolete
GREEN SALES CO. in Cincinnati OH has THREE = 800-543-4959.
C7TZ-7210-L .. T/C Shift Lever ~ 1967/72 F250 4WD / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Old 03-29-2013, 05:43 PM
Bad 674x4's Avatar
Bad 674x4
Yes will have to fabricate,just wanted to know if the 66-77 bronco look the same has the 67-72 shifter.Want the interior to look stock.
Old 03-30-2013, 01:53 AM
RichS2659's Avatar
RichS2659
One thing you can do is to take off your present shift lever, cut it off to a stub, then weld a TC shift lever or a cutoff 4 speed shifter to it, and re-install it to save you from fabricating a complete shift mechanism for the BW-1356 TC.
F350moneypit
15
04-03-2017 11:08 AM
Cactusjack01
07-11-2016 07:32 PM
schoo
05-15-2013 06:55 AM
weyland426
01-12-2010 06:16 PM
erniech
1966 - 1977 Early Broncos
06-25-2006 12:25 AM
Quick Reply: Stock transfer case shifter for 1967 -1972
