20 inch Wheels and 3.31 gears
Been reading all the tire/wheel threads. I've seen conflicting info and some good points.
BUT IS ANYONE RUNNING 3.31 gear and 20 inch wheels without the CEL?
I've got a set of factory 20's that needs tires and I'm really wanting to run them on my truck. But I don't want to shell out the big $$$ for rubber and then not be able to use them.
I understand that the tuck knows it has 3.31 and therefor can't have 20's so the tech can't program it think it does. I have the 275/70/18 right now and I know there isn't much difference in tire height to the 275/65/20 (less than an inch I think)
The speedo reads fast right now. 60 MPH is 56 on the gps and side of the roadway "your speed is" radar.
May look and see if I can make a friend that would let me use a set of factory 20's and try them out.
Any ideas are welcome Please post
The check engine light comes on when you try to program your new wheel size into the computer, problem being it was not a factory configuration. You can put them on your truck no problem, its just going to change the speedo readings accordingly. Which as you stated, will probably make it more accurate.
Been there with this. I had the same tires the OP had. I put on 295/70/18 Nittos. The 275/70/18 is the largest 18" wheel setting available. Fortunately my speedo read about 3mph fast before I changed the tires and now reads exact without re-programming anything. (Although I did try to see if the dealer could do anything and as predicted they selected a 20" wheel and it threw a CEL.)
Although one person did actually find a way. He had them also change his axle 3.55 allowing them to select a 20" wheel. Not sure if that is a good idea or not.
tomstoner06
6.7L Power Stroke Diesel
07-03-2015 01:01 PM
