What is this on my wheel
No, but that sounds dangerous to do. Although, I do have antiseize on the hubs. It was copper too. maybe... it got hot and pressure flowed out? or just washed out with some small clearance? Its been almost a year since i put the wheel on last
Dangerous is probably overstating it, but if you put any kind of schmoo on your lugs, you're not going to get accurate torque values, and you do run *a* risk of having the lug nuts back off over time. I would be lying if I said I'd never done it, especially if I've got a lug with mangled threads, that I just needed to get home, but I've always swapped it out at the earliest convienience.
The Torque specs on lug nuts/bolts is specifically a "Dry" Torque.
If you put schmoo on the threads, and torque it down to the dry spec, you could very well be applying far more torque to the fastener, than it was designed for.
The following users liked this post:
The apart im most worried about is the fact it hasn’t done this before but I have been driving 80+ mph shots on the freeway lately and I would be lying to say it hasn’t been high winds+raining+ lots ot heavy braking or hust otherwise cool mornings and hot days so thermo cycling. I suppose all that is possibly contributing.
TheBurk
1999 to 2016 Super Duty
19
05-10-2019 07:34 PM
