Pats problem? - Page 2 - Ford Truck Enthusiasts Forums
Pats problem?
Old 04-05-2013, 02:54 PM
mutang02 mutang02 is offline
mutang02 is starting off with a positive reputation.
Ok i tried again. This time I did it while running and it still read 5284. Is there a way to reset that? Also when cycling through to get to the dtc portion of the readout one of the areas says EE, and is flashing between fail and 01. Does this mean anything? Thanks
Old 04-05-2013, 04:43 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
The EE display flashing says to replace the insturment panel.
Your at the the end of this situation , now.
You just saw the value and reason why there is a dash diagnostics procedure otherwise you would never know except change the dash cluster on a guess.
Only possability left is componant solder connnections on the circuit board might be recovered, if that is the problem, using a low wattage iron and some solder, inspecting with a magnifying glass, the connection points.
Good luck.
Old 04-06-2013, 10:13 PM
Sweet thanks. Now it's time to decide whether to just buy a new one from dealership for $450 plus install and programming, or get one from the you-pull- it, then get the dealer to program it to the keys.
FICM Power Relay Problem Hint DSMMH 6.0L Power Stroke Diesel 0 01-31-2015 09:10 AM
Pre 87 EXTREME glow plug failure we287gn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 01-04-2015 06:42 PM
Help with starting problem abranz Excursion - King of SUVs 5 11-16-2014 01:07 AM
PCM or fuel pump? jlgriff76 1987 - 1996 F150 & Larger F-Series Trucks 3 10-14-2013 01:56 PM
really hard start Combat Engineering 1999 - 2003 7.3L Power Stroke Diesel 20 02-28-2010 08:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
