Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
tourqe converter
Old 03-28-2013, 06:12 PM
yomow's Avatar
yomow
yomow is offline
tourqe converter
Hi, i have a 1994 lighting ,pulling engine to check main & rod bearings . Is there anyone that has upgraded the converter on a E4od trans. Truck is stock , & might put in a camshaft Upgrade . Truck has been sitting for 7 years & just do the bottom end to freshen it up with oil pump . truck has 79,250 miles on it . Going to my Son , he is getting Married & wants a truck ..
Old 03-28-2013, 08:38 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Circle D specializes in converters for E4ODs and 4R100s for GEN 1 and GEN 2 Lightnings. They have a higher stall speed (your choice), billet front cover, fully brazed internals and 3 or 4 clutch configurations that is far superior to the stock, single disk converter.
It's likely that the block in that truck is an F4TE casting and will accept a roller cam conversion relatively cheap. I have purchased several used sets of roller accessories for less than 100 bucks; roller lifters, spider and dogbones. You can find these parts in mid 90's F-series 5.0 trucks and 87 and later 5.0 mustangs; just keep an eye out on ebay, craigslist and/or the corral. You'll also need to change the distributor gear out to a steel piece if you do go with a roller cam.
Old 05-16-2013, 01:44 PM
yomow's Avatar
yomow
yomow is offline
I thought the 1994 lighting motors are roller motors .
Old 05-18-2013, 08:21 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Most came with an F4TE block, from mid 93 and newer. However, none of them came with a roller cam from the factory.
reed1951
20
01-09-2008 09:19 PM
jklennon
12-25-2006 11:21 PM
s1120
09-20-2006 09:34 PM
badassfordpu
20
01-09-2005 01:41 PM
carp1
03-25-2002 07:05 PM
Quick Reply: tourqe converter
