Engine pinging after tune-up - Ford Truck Enthusiasts Forums
Old 03-28-2013, 03:56 PM
DoofusOfTheDay's Avatar
DoofusOfTheDay DoofusOfTheDay is offline
DoofusOfTheDay is starting off with a positive reputation.
So, brought my 1995 F-150 5.0L to guy who gave it a tuneup, new spark plugs, distributor, wires. Well now it's running a little rough and engine is pinging when say I am going up a hill. If I floor it, it will stop pinging and knocking, but I shouldn't have to do this. The last thing he mentioned to me before I picked up the truck after tuneup was re-doing the timing, so maybe he forgot to do timing? But am confused as I thought there was no way to adjust timing on this engine, if timing is bad all you can do is replace ignition module? Unless my reading up about this is wrong.
Old 03-28-2013, 04:03 PM
Fletch_lives's Avatar
Fletch_lives Fletch_lives is offline
Fletch_lives is starting off with a positive reputation.
The timing is adjustable,he probably set it wrong or something.
Old 03-28-2013, 04:12 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
The base timing IS adjustable, (the factory calls for 10, but most find around 12 gives a little more power and economy) but all of the advance work is done by the computer.. He may have adjusted the timing without pulling the spout connector, if he did the timing is probably around 12-15 too far advanced.
Go here Fuel Injection Technical Library How To Run a Self-Test to see what and where to look for the spout connector... The second picture shows where to look.
Old 03-28-2013, 04:17 PM
Freightrain's Avatar
Freightrain Freightrain is online now
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
He probably bumped it up a few degrees, and it doesn't like it. Typical. Mine was just as bad at one point.
Old 03-28-2013, 04:55 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Check to make sure he did not cross the #7 and #8 spark plug wires.
Old 03-28-2013, 05:51 PM
No 7 and 8 aren't crossed. I imagine that would make it run real poorly if they were.
Old 03-28-2013, 07:09 PM
Immortal_Ben's Avatar
Immortal_Ben Immortal_Ben is offline
Mechanic by Necessity
Immortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud of
Quote:
Yup. And probably backfire.
Old 03-28-2013, 10:07 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.
Yeah back the base timing off. I tried 13* advanced base timing and she didn't like it. 11* works but more than that and it pings. That mechanic shoulda test drove it. If you paid him for the work, bring it back in and ask him to back the timing off a little, explaining that its pinging under load. Just don't ignore it! 10* with SPOUT connector unplugged is factory base timing.
EDIT: the timing adjustment is simply loosening the distributor hold down bolt and turning the distributor. IIRC clockwise retards timing and counterclockwise advances, but I could have that perfectly backwards.
Old 03-29-2013, 12:45 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Quote:
Hooking up the SPOUT allows the computer to advance the timing. Setting it that way would require you to back all of the computers advance out of the base timing which would result in retarded timing, not advanced. If that happened it would run poorly and suck gas, but it definitely would not knock. Still likely that timing was set too far advanced, just not in that way
Old 03-29-2013, 01:02 PM
Quote:
I'm pretty sure that CW advances the timing and CCW retards it. But I've been wrong about things I've been pretty sure about before too. Bottom line: check the riming before you move the distributor, move it a little and check it again. You'll see if you went the right way or not.
Old 03-31-2013, 07:11 PM
Ricky Cox's Avatar
Ricky Cox Ricky Cox is offline
Ricky Cox is starting off with a positive reputation.
Quote:
Definitely is, I bumped my timing up today as well.
Old 03-31-2013, 09:59 PM
Thanks for the clarification guys. That means the distributor rotor spins CCW, right?
Old 04-01-2013, 06:25 PM
Nope, it turns CW. This is where I always get yself al twisted around and by the time I'm done I'm doubting myself. So I'll see if I can explain it without getting all of us confused.
Advanced timing means the plug fires earlier. So to advance the timing you want to turn the rotor backward (CCW), so it's farther in front of the post on the cap. But you don't turn the rotor to adjust the timing, you turn the cap (and the rest of the distributor). So you turn it the opposite direction or CW to advance the timing.
Old 04-16-2013, 03:36 PM
Well, brought it back and he rechecked and it's at 10 degrees. So, it looks like maybe I should ask him to bump it to 11 degrees? Of course this is all assuming that's the issue.
Old 04-16-2013, 04:52 PM
1993_f350_2013's Avatar
1993_f350_2013 1993_f350_2013 is online now
1993_f350_2013 is gaining momentum as a positive member of FTE.1993_f350_2013 is gaining momentum as a positive member of FTE.
what spark plugs did he put in? these motors run the best with regular motor craft coppers
89 5.0 ping Martin Torres 1987 - 1996 F150 & Larger F-Series Trucks 19 01-12-2017 12:41 AM
2004 5.4 F150 tuneup ???'s my150 2004 - 2008 F150 4 03-04-2015 12:55 PM
Tune-up Specs Questions rpaxton939 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-07-2014 09:51 AM
Fuel pump duty cycle XLT2.5L Ranger & B-Series 10 10-03-2009 11:06 PM
2000 3.0L PINGING solved! thinkirish Ranger & B-Series 4 05-09-2004 03:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
