1988 F250 460 engine swap - Ford Truck Enthusiasts Forums
Old 03-28-2013, 02:06 AM
Jobo57's Avatar
Jobo57 Jobo57 is offline
Jobo57 is starting off with a positive reputation.
New to forums so hopefully I'm doing this right..
Hello all I was just wondering if anyone had any experience/advice with current situation.
I have a 1988 f250 4x4 with a fuel injected 460 and a C6 trans. I'm trying to get a new engine for it and I found a nice one for pretty cheap. It's a 460 from a 1993 F350 and i'm wondering if it will go easily into my truck. Im not sure what kind of trans the engine had but I'm assuming a e4od. Any help would be appreciated
Old 03-28-2013, 04:22 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
No major difference, the F3 heads flow a little better.
It should drop right in.
Old 03-28-2013, 12:51 PM
Jobo57's Avatar
Im not familiar with f3 heads, are those on the '93?
Old 03-28-2013, 01:31 PM
pedant
Yes, the E7 heads were updated to F3 in 1993.
The block and most everything else is exactly the same.
Old 04-06-2013, 01:21 AM
Jobo57's Avatar
Just found out my engine is actually a 1996. Or at least i think so. There is a tag on the side of the valve cover that says "meets all emissions standards for the model year 1996" . Will a 1996 still be able to drop into an 1988?
Note: I only plan on using the long block
Old 04-06-2013, 02:12 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
There is no major difference between the engine you have and the proposed donor. Go for it!
Old 04-06-2013, 09:06 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
All efi 460s will bolt in place of one another. Just use your old flywheel or flexplate and all the wiring from your truck (not the donor motor) and if the distributor is different youll need to swap that.
1988 F250 460 - compatible models/trans Finger__Rachet 1987 - 1996 F150 & Larger F-Series Trucks 6 04-28-2014 09:34 PM
1988 F-250 460 engine wire harness mttmxwll 1987 - 1996 F150 & Larger F-Series Trucks 0 01-09-2010 02:37 PM
1989 460 into 1995 F250 Burn21 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 09-08-2003 01:21 AM
1989 460 into 1995 F250 Burn21 1987 - 1996 F150 & Larger F-Series Trucks 0 07-01-2003 02:59 PM
1989 460 into 1995 F250 Burn21 1987 - 1996 F150 & Larger F-Series Trucks 0 06-27-2003 05:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
